Sticky Turn Signal Switch - Wrist Twisters
 1Likes
  • 1 Post By Devin4242
post #1 of 12 Old 12-28-2013, 07:58 AM Thread Starter
Ride with grace.
Devin4242's Avatar
My turn signal switch is failing to fully engage when the temperature dips below freezing, and I have a feeling I just need to lube it somehow. I don't want to douse the contacts though - any ideas? Maybe something graphite? I'll take it apart if I need to, but if there's a quick fix, it would be appreciated. Aside from not riding in the cold...
Devin
Isaiah Wright likes this.
Devin4242 is offline
post #2 of 12 Old 12-28-2013, 10:11 AM
No need to take it apart. Just spray some wd-40 in there. It won't hurt anything.
post #3 of 12 Old 12-28-2013, 09:59 PM Thread Starter
Ride with grace.
Devin4242's Avatar
Good to know. I've had issues with some older components using WD40, but in this case I'll give it a whirl.
Thanks!
post #4 of 12 Old 12-28-2013, 11:42 PM
+1, I used brake cleaner but same idea. Works well.
NZspokes is offline
post #5 of 12 Old 12-29-2013, 12:16 AM
Careful with brake cleaner, though. It eats stuff!
post #6 of 12 Old 01-01-2014, 02:04 PM
Delraco's Avatar
Like paint. and some types of plastic.
brake cleaner is unfortunately a risky idea. it will also dissolve the grease that's supposed to be on the mechanism in there. if yours is sticky, it just needs lubing!
I used some chain wax as the spray can has the fitting to reach way into the mechanism much like the wd-40 can. only difference is the chain wax will stick better and should last longer. Did the trick nicely!
Delraco is offline
post #7 of 12 Old 01-01-2014, 04:40 PM
On another bike, I got some brake cleaner on the gauges and it ruined them. I could barely polish out the damage.
post #8 of 12 Old 01-01-2014, 04:48 PM
doing this now!
post #9 of 12 Old 01-01-2014, 07:05 PM Thread Starter
Ride with grace.
Devin4242's Avatar
WD40 worked, so far, but when I put the new bars on, I'll probably do some retro maintenance. Amazing what cold will do. I had a late model Ford Probe many years ago in Chicago (like 20) and when it was 18 below zero, the door hinges squeaked regardless of their age. I'll take 25 degrees and a little effort over flippin' cold any day.
post #10 of 12 Old 01-01-2014, 07:10 PM
I'd use some sort of dielectric grease. It does not conduct electricity so you dont have to worry about it shorting anything out.
you just have to find one that lubes well in your temperature.
post #11 of 12 Old 01-01-2014, 08:28 PM
rpcraft's Avatar
Stick with WD40 because although its application is wet, once it still lubricates. The lubricant is dry. The wet portion helps with penetration and coating
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #12 of 12 Old 11-20-2018, 07:29 PM
Isaiah Wright's Avatar
Glad I found this thread. Thanks for the help!
Isaiah Wright is offline
