Steering head bearing - Wrist Twisters
post #1 of 8 Old 02-10-2014, 05:47 PM Thread Starter
Okay, need some help here. I've put the lower triple on the SV, and have run into a slight snag. When turning it side to side, it feels like there is a little resistance at some point (like a notch), then is fine again. For those that have worked with these before, a couple of questions:
Is it possible that I just have it a little on the tight side? Just enough to cause some binding? Or would it be evenly tight as I turn it? They are tapered bearings, BTW.
I'm pretty sure I got the races in straight, but would the slightest offset (say less than 1mm) cause similar symptoms?
One other piece of info: I took the stem out and put it back in, and the point at which it sticks moved...
Thanks for any help. Hoping I don't have to punch the races back out!
Stu
post #2 of 8 Old 02-10-2014, 06:36 PM
A hair out of square will do it.
How clean were the receiving bores ?
Did you check to see that all races are perfectly registered ?
post #3 of 8 Old 02-10-2014, 07:12 PM Thread Starter
Made sure the bores were clean and burr-free. I think I got it sorted now, though; I tightened the nut a smidgen too much. Loosened it about 1/8 turn, tightened the top nut, and now it's smooth without having any play. It's been a little trail and error to get it just right, because tightening the top nut snugs things up just a bit.
For future reference, when you say perfectly registered, is there a good way to check? I did the best I could to examine with a small mirror, but I doubt that would've shown me a small gap. I tapped them, using the old races, after installation to try to be sure they were fully seated, but that obviously wouldn't fix things if a shaving had gotten in between...
post #4 of 8 Old 02-10-2014, 08:16 PM
sometimes if you tighten it too much you can put a flat spot on one of the ball bearings fyi.
post #5 of 8 Old 02-10-2014, 08:23 PM Thread Starter
That was one of my concerns, and hopefully not the case. Hopefully the fact that it smoothed out means this wasn't the case. The instructions gave a torque setting to start with to get things seated, then I loosened from there.
post #6 of 8 Old 02-10-2014, 09:05 PM
I usually over tighten them a touch, not stiff and notchy but overly snugg.... then roatate the triples to seat everything. Then back it off until the head set motion feels right, with no play.
post #7 of 8 Old 02-10-2014, 09:45 PM Thread Starter
It's funny how little it takes. The lower nut is barely finger tight.
post #8 of 8 Old 02-12-2014, 04:36 PM
If space permits, try to do a feeler gauge check between the seat of the bore and the registering end face of the outer race.
2 thou max feeler, you want it thin and easy to curve with a tight radius so you can attack the intended check points.
No feeler should go in.
A strip of shim stock can be cut and used as well.
