Starting issue - Wrist Twisters
post #1 of 49 Old 05-05-2009, 07:57 PM Thread Starter
Starting issue
Hoping someone might have a lead on this for me. I'm having an issue on my 03 919 where right at startup the bike will die once your thumb comes off the starter. Two basic methods and outcomes:
1) turn on key
2) pull enricher knob
3) press starter (engine cranks, fires, runs what seems to be normally)
4) let go of starter
5) bike stops
or
1) turn on key
4) rev bike to a few thousand rpms for a second
5) let go of starter
6) engine drops down to near zero rpms for an instant, just long enough to wonder if it died, then fires and runs as if nothing is going on
So, if anyone has any ideas for me...
FWIW I did reset and reload my power commander to no avail. I haven't removed it completely yet to see if that is what is causing the problem.
bigassbertha is offline
post #2 of 49 Old 05-05-2009, 07:59 PM
I killed Barton664
Basspiece919's Avatar
I have never used my choke knob... Is your idle set ridiculously low?
Basspiece919 is offline
post #3 of 49 Old 05-05-2009, 08:08 PM
what happens without using the enrichenererer thingie
post #4 of 49 Old 05-05-2009, 08:11 PM
Scott
Wraith53089's Avatar
I only use the choke/enricher when it's really cold.
Do you wait for the fuel pump to stop before you hit the starter or just turn the key and start. You should wait for the pump to stop that way you know that the fuel lines or fully pressurized.
Wraith53089 is offline
post #5 of 49 Old 05-05-2009, 08:33 PM Thread Starter
Same thing happens without the enricher, I just figure that I ought to have it on since I have to rev it on startup to start the bike.
If the bike has been shut off right after riding, the problem does not exist. It will fire right up.
I do wait for the fuel pump to stop, I usually flip the key on, put on my helmet, then start it up.
Thanks for your posts guys.
post #6 of 49 Old 05-05-2009, 08:43 PM
I killed Barton664
I am confused. So it does start sometimes? You always use the "enricher"? When it does start up what does it idle at?
post #7 of 49 Old 05-05-2009, 08:51 PM Thread Starter
Either I don't rev the bike and it dies, or I rev the bike to 3-4 grand for a bit with my finger still on the starter button, let off the starter button, it nearly dies and then kicks in. I just walked out, turned the idle way up beyond where it was and same problem.
The only time that it starts without revving is seconds after the bike is shut off hot.
The "enricher" doesn't change anything in this at all, I'm just a little more comfortable revving it cold with the enricher on.
post #8 of 49 Old 05-05-2009, 08:57 PM
I killed Barton664
I have no ideas... but as we established in my thread a little bit ago I am not the one to ask. Someone will chime in any minute and tell u lol.
post #9 of 49 Old 05-05-2009, 09:17 PM
Mine is the exact same way...I hate it. Please come up with a fix.
Bryce919er is offline
post #10 of 49 Old 05-05-2009, 09:37 PM Thread Starter
Have you posted anywhere else about it? And are you using a power commander as well?
Glad to know I'm at least not alone... but sorry you've got the same problem.
post #11 of 49 Old 05-05-2009, 09:46 PM
Yes I have the PCIII, it has not always been like this with the PCIII, never like this without it but had the PCIII on the last 3 years now. Read my posts #19 & 29 here
https://www.wristtwisters.com/forum/s...ighlight=PCIII
This is what you have as well right?
post #12 of 49 Old 05-05-2009, 10:02 PM
Heavy Metal
ratdog's Avatar
weird
starter...hmmmm...stayin on the starter keeps the engine going when it lopes to the low idle, i'm guessin...which is just masking the actual symptom
so it's a cold start issue, and a short one at that...
ratdog is offline
post #13 of 49 Old 05-05-2009, 10:14 PM Thread Starter
Yes Bryce, sounds like my problem as well.
post #14 of 49 Old 05-05-2009, 10:14 PM
If I was having this trouble, removing the PCIII would be the first thing I did. From what I've read on this forum the past couple of years, it is the source for a lot of weird problems.
post #15 of 49 Old 05-05-2009, 10:21 PM
Heavy Metal
ratdog's Avatar
+1 and it's easy to do
ratdog is offline
post #16 of 49 Old 05-05-2009, 10:59 PM Thread Starter
And I figured that that was step #1 IF no one knew of a fix.
post #17 of 49 Old 05-05-2009, 11:35 PM
it's a honda, not a bmw
deuceWI's Avatar
I better join in and share.
I have an 03 as well, with a PC3, and she always needs a blip of throttle to start cold. Before the PC3 was installed I don't recall this ever being an issue. I also don't worry about it at all since it just works. Idle is currently set around 1100 (if the tach is accurate) which I think is a bit low, but I like how it sounds where it is so I'm not going to mess with it.
deuceWI is offline
post #18 of 49 Old 05-05-2009, 11:48 PM Thread Starter
Mine's had the PCIII for 4 or 5 years but just recently started doing this after sitting for a winter. Not really sure why it would **** out now, but I will give it a try and pull it eventually.
post #19 of 49 Old 05-06-2009, 05:49 AM
Heavy Metal
ratdog's Avatar
yeah that is weird but let me ask you something
are you at all 0's in the 0% throttle position AND are you using the Accelerator Pump function??
ratdog is offline
post #20 of 49 Old 05-06-2009, 09:30 AM
deuceWI's Avatar
ahhhh, I think I see where this is going.
I believe my throttle position is calibrated so 0%=0. Does the stock tune differ from that?
And I have some recommended settings for the accelerator pump as well. Not sure what they are at exactly, but it is enabled.
deuceWI is offline
post #21 of 49 Old 05-06-2009, 10:08 AM Thread Starter
Zeros are zeros, no accel pump
post #22 of 49 Old 05-06-2009, 03:14 PM
Heavy Metal
ratdog's Avatar
turn off accel pump
calibrate throttle per instructions
now i really want to know if the same thing happens w/o the pc3
and again, this came out of nowhere right, everything was fine for years and then bam?
ratdog is offline
post #23 of 49 Old 05-06-2009, 03:42 PM
My 04 does it too, disconnect the PCIII and it fires right up, reconnect the PCIII and I have to blip the throttle to get it to stay running, but since it runs worse with the PCIII disconnected (3k rpm surge) I'm learning to live with it.
post #24 of 49 Old 05-06-2009, 08:25 PM
No acel pump here, all zeros @ 0% & I have tried reseting the max/min throttle positions on the PCIII. I have not disconnected the PCIII because it is a pain to get to those ECU connectors, especially since I have a Ventura. Besides, I want to run the PCIII, I just wish this did not happen. Whats frustrating is it has not always been like this (& I have run the same map in the good times & bad).
Part of me wonders if my battery has someting to do with it. It is the original that came with my 02. At the end of the season when cold weather makes rides few & far between sometimes my bike won't crank. I only got a "tender" last winter & just charged it sporatically all the years prior. Does anyone with this problem have a fresh battery or tried replacing it?
post #25 of 49 Old 05-07-2009, 02:01 PM Thread Starter
My battery is brand new as of a few weeks ago, and made no change whatsoever. I'm going to toy around with it and see if I can't figure something out. Will keep all updated.
At least we know it's something to do with the PC, but since my bike will run like a turd without it I'll be trying to figure out how to get around it.
post #26 of 49 Old 05-07-2009, 02:22 PM
deuceWI's Avatar
Additional observations from me:
Overnight cooldown, parked inside and cool, push button, no throttle = no start.
4 hour cooldown till lunch, bike parked outside on a warm sunny 70F+ day, push button, no throttle = start.
This tends to be how it works for me, and like I said, I have just got in the habit of blipping the throttle. If a PC3 tweak fixes things, I'm all for trying that.
Tomorrow may be rainy, but just to confirm I might try to go fire her up without the PC3 in the morning just to see what happens.
deuceWI is offline
post #27 of 49 Old 05-07-2009, 02:32 PM Thread Starter
That's not quite my experience. Regardless of outside temp, if the bike wasn't running and warm within several minutes of starting it back up, it takes a throttle bump to start.
post #28 of 49 Old 05-07-2009, 02:39 PM
deuceWI's Avatar
The middle of the sunny day cold start is noticeably slower than a warm restart after a ride. It takes a few seconds for the idle to pick up to normal. But it's not nearly as bad as a cold cold morning start that needs a little help.
deuceWI is offline
post #29 of 49 Old 05-12-2009, 03:34 PM
deuceWI's Avatar
Lets see if this link works.
It's an example of my cold morning startup.
Is this the problem?
I will try to get moving a bit early someday soon so I have time to disconnect the PC3 before heading to work and see if it acts differently.
deuceWI is offline
post #30 of 49 Old 05-12-2009, 04:06 PM
Hmmm... My 919 sat in cold storage for 6 months and it started as if it was running 6 minutes ago.
post #31 of 49 Old 05-12-2009, 04:19 PM Thread Starter
That is exactly what mine does, but evidently I have to rev the everliving shit out of mine to get it to stay going. I can't just crack it. I'll see if my video cam works when I get back home (away for work) and try to post it up as well.
Thanks for posting that!
post #32 of 49 Old 05-12-2009, 04:45 PM
So, Satan's our mascot?
SuedeGopher's Avatar
+1 on the described problem with PCIII - also didn't used to be an issue.
SuedeGopher is offline
post #33 of 49 Old 05-12-2009, 05:12 PM
USMC
beardlessj's Avatar
crazy stuff. and to think i was going to get one. now i will have to find somthing else.
2007 CB919 37 mi Aug 20 2008
beardlessj is offline
post #34 of 49 Old 05-12-2009, 05:55 PM
YES!!!!!!!!!!!!!!!!!!!!!
MINE DOES EXACTLY THAT!!!!!!!!!
I'm excited that at least Im not alone.
Maybe I never tried cause I get so pissed but I have to rev mine harder to go.
post #35 of 49 Old 05-12-2009, 10:39 PM Thread Starter
PC3, not the bike.
post #36 of 49 Old 05-13-2009, 05:58 PM
BrokeRecord
What?
What exactly does the PC3 do besides cause trouble? I never bought one, but, if I did and expieranced the problems with start, missing, and idle that lots of you have, then I'd hit that booger real hard with a claw hammer. What good is 3 HP if the bike won't start?
brokerecord is offline
post #37 of 49 Old 05-13-2009, 07:55 PM Thread Starter
I got hit by a car in 03. It was $900 some for replacement stock exhaust, or $150 for a used exhaust + $250 for the PC3 to make it not run like a pooch.
post #38 of 49 Old 05-18-2009, 07:47 AM Thread Starter
Anyone have any experience with Dynojet's customer service? I emailed them middle of last week and haven't heard a peep.
post #39 of 49 Old 05-18-2009, 08:37 AM
wisco919's Avatar
+1. Never have had any starting issues even with the PCIII.
wisco919 is offline
post #40 of 49 Old 05-18-2009, 01:30 PM Thread Starter
Mine worked perfectly for 5 years. Until it didn't.
