Starting bike with choke - Wrist Twisters
 3Likes
  • 1 Post By mcromo44
  • 2 Post By Islandboy
post #1 of 15 Old 08-31-2017, 09:57 PM Thread Starter
Hey you guys helped me get my bike running after a 1 1/2 years of sitting because of an illness I had, so the bike is running now. But starting it I'm having a hard time getting it started. I have to choke the engine to get it started. Once it starts I can push the choke in and the bike runs fine idles fine, never had this problem before only in cold weather starts I had to choke the bike. Now I'm worried that in cold weather I'll have a real problem stating it if I have to choke it when it's 70 degrees out. Took the bike out for a good ride filled the tank with some new high test gas, but after sitting it still needs the choke to start. There was a green wire which I forgot which terminal it went to on the battery, however it wasn't red so I put it on the neutral. The power commander seems to be fine I guess lights light how they should when I hit the throttle. Any ideas or is this just something that I will have to deal with and is normal for an 04' Honda 919. Thanks in advance guys
Just_smith is offline
post #2 of 15 Old 09-01-2017, 10:02 AM
BockHawk's Avatar
If it's not too much of a chore, I'd suggest trying to start without the Power Commander installed. If it runs normally without it, you've got your culprit.
2002 919 40,000 miles
BockHawk is offline
post #3 of 15 Old 09-01-2017, 09:20 PM Thread Starter
That maybe a chore for me that's what i had read online that it maybe the Power Commander, but I love the way the PC smoothed the ride out. It's funny after the initial start the bike starts all day just fine it's just the initial start after sitting for a day or two.
post #4 of 15 Old 09-02-2017, 01:03 PM
Power commander cold start issue. My bike had it. Long holds of the start button after bike fired or repeated start attempts when cold. Then start fine all day when warm. I've fixed my cold start issue using Rob's diode shunt fix. Very simple, very cheap. Power commander is still on bike and bike starts immediately, regardless of bike engine temp, hot or cold. Awesome.
post #5 of 15 Old 09-05-2017, 04:19 PM
Great news.
Tharlson should get at least a case of good beer re this.
TheScientist likes this.
post #6 of 15 Old 09-05-2017, 06:15 PM
Bugger that. I'll send him a little bottle of Aussie rum. The shipping on a box of beer across the pond! Just kidding I owe him big time.
Robs diode fix post had been up for a while. Didn't look like anyone had tried it. I had read it before, but I was ignorant of the whole flyback voltage thing so just blew it off. I tried everything else everyone else had tried, no success. Was about to give up and was going to fling the power commander. I had emailed another fuel controller crowd. They could retro fit a newer model controller to the 919, it can add and subtract fuel. Hundreds of dollars. Besides the cold start problem I liked the power commander. I thought what the hell one final go at fixing it. Tried Rob's diode shunt (followed his instructions) instant cold start. Success. I was gob smacked. Also very cheap and easy. I have since googled the crap out of flyback voltage. Which I new nothing about. It all make sense now.
Be be good if someone else could confirm diode fix. Must be sure power commander is the cause of the issue.
Thanks Rob. I wish your bike brain came as a pdf.
mcromo44 and TreetopFlyer like this.
post #7 of 15 Old 09-05-2017, 09:28 PM Thread Starter
Sounds like my problem once the bike starts it starts all day fine. Where can I find Rob's fix thread? Should I just google the key words or how far back is the post? And is it really that easy I'm pretty much not mechanically inclined, but willing to try to keep the PC on board it really improved the ride of the bike in my opinion. Also is there any real reason not to just choke the bike to start it other then it being an annoyance?
post #8 of 15 Old 09-05-2017, 10:44 PM
First do what Bockhawk suggested. Remove the power commander. Run the bike stock and see if the cold start issue is still there. Then you'll know where to go next.
post #9 of 15 Old 09-06-2017, 09:41 AM
just ignore the "choke" (it's really more of a fast idle since there are no carbs, but that's just semantics) and just hold the starter button down for a few extra seconds when starting cold. totally fixes the problem with no intervention necessary.
post #10 of 15 Old 09-10-2017, 01:21 PM Thread Starter
Thanks I try that but the bike doesn't start when I hold the start button and it seems like the start cycle ends for that depression of the starter it seems like I'm just going to kill the battery. Should I still just hold the button and will the starter cycle through again while I have the button depressed?
post #11 of 15 Old 09-10-2017, 06:01 PM
Let me get this right.
Your bike has to turn over several times before it fires and starts?
Or does the bike start mostly straight away but dies the moment you release the starter button unless button is held in for several seconds after starting then it remains running?
post #12 of 15 Old 09-17-2017, 10:18 PM
derpydog's Avatar
Wait, I thought you were describing the PC cold start problem too until this. This just sounds like your battery is dead.
Fine, I'm adding a signature, leave me alone!
derpydog is offline
post #13 of 15 Old 09-17-2017, 10:55 PM
Yeah I was thinking the same thing, maybe it's not the cold start issue. That's why I was asking for a better description of the start symptoms.
post #14 of 15 Old 09-21-2017, 08:39 PM Thread Starter
The bike never turns over with the start button pressed even if I hold it in for several seconds. The bike seems like it wants to start but just doesn't turnover. The battery is still is strong after multiple attempts but I'm afraid of multiple attempts this way is going to kill the battery. As soon as I pull the choke out on the bike it starts on the first attempt. I was questioning the battery because it needed a charge when I purchased it and then after the charge I still had to jumpstart the bike to get it running, however since that initial start it has not had a problem just in the back of my mind it's a concern. And after the initial start the bike starts all day with out pulling the choke out or holding the start button for an additional amount of time.
post #15 of 15 Old 09-22-2017, 10:41 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
Have you checked the voltage drop when cranking the engine before it catches?
ST-DocLizard1 is online now
