squeeking breaks - Wrist Twisters
post #1 of 18 Old 07-23-2009, 08:08 AM Thread Starter
mantelhonda's Avatar
squeeking breaks
changed my front pads about two weeks ago, using Honda pads. that's when the squeeking started. It happens only under lite to moderate breaking . I have checked and rechecked every thing, my rotors are straight, the calipers were installed and torqued per manual, I have also checked the wheel and axle , all good, and the pins holding the pads were cleaned and lightly lubed. breaks operates normally other than the noise. Has any one else had this issue before and how do you fix it, any help here is greatly appreciated.
mantelhonda is offline
post #2 of 18 Old 07-23-2009, 08:14 AM
use the hell out of them..... get going fast as you feel safe and try to stoppie that thing.... they will quit squeaking pretty quick...
thats what i always did with mine...
post #3 of 18 Old 07-23-2009, 09:15 AM
Steve
Mayday's Avatar
This is a known issue on some 9ers.Try searching,there is a huge thread on this. Like you, I have tried everything multiple times and it still squeals like a banshee under light to moderate braking. Only 9k miles on the bike.
My calipers/rotors are so clean you can eat off them-no difference.The only known fix is to replace the stock rotors with galfers which will set ya back bout $600. FWIW...I can take 100 grit sandpaper and sand both sides of the rotors and the squeal completely stops for bout 100 miles but it always comes back. Not sure how/why.
I have new EBC HH sinterd pads installed now but it was the same prob with the stockers.
Good luck man, I gave up and am currently saving for galfers but would love to be able to fix it on the cheap. Post up if ya figure anything out.
Steve
Mayday is offline
post #4 of 18 Old 07-23-2009, 03:55 PM Thread Starter
I should have known you'll come up with a solution like this, LOL. Last time I tried a little showing off, I almost eat ##it in front of two dozen people, and at my age, with my weight,it could have been embarrassing and painful . I have been hard on the breaks on more than few occasion ,but the squeak is still there.
post #5 of 18 Old 07-23-2009, 04:28 PM
snowytgr1's Avatar
I guess I was lucky as I just replaced my pads and I have no noise at all, hopefully it will stay noise free. I bought OEM pads and have maybe 100-200 miles on the new pads. Did your noise start right after replacing the pads or did it take some usage before noise started?
snowytgr1 is offline
post #6 of 18 Old 07-24-2009, 08:06 AM Thread Starter
lucky you I noticed the noise within a couple of days of installation about 400 miles , I also have OEM pads. I am thinking of changing the pins that hold the pads, I can't see any damage on them, but if one happens to be slightly bend it could effect the pads movement, according to the service guy at the dealer. I'll post up once I get the pins.
post #7 of 18 Old 07-24-2009, 09:26 AM
Steve
Mayday's Avatar
Break Squeal-more info
FWIW...Mine started squealing immediately after having a new tire put on the front by the dealer. I still had the stock pads on at that point. I installed new pads to see if it would help but that did absolutely nothing. I have cleaned and reassembled everything multiple times. I can rag on the brakes like a stunta but it makes no difference. If I scuff up the rotors with 100 grit sandpaper the squeal stops for a couple hundred miles but comes back. (There may be a clue there somewhere) I'm out of ideas. Post up it ya solve the mystery! Good Luck!
Steve
Mayday is offline
post #8 of 18 Old 07-24-2009, 11:46 AM
Praefectus Castrorum
brevity's Avatar
It's a common problem with a plethora of home remedies which don't work (if they did, it wouldn't be a common problem...).
Don't sweat it. It has absolutely no adverse effect on your bike's ability to stop.
brevity is offline
post #9 of 18 Old 08-06-2009, 10:09 PM
Swap rotors from another model?
I have the same problem. I've gotten used to it, but if I can do something about it cheaply, I'm all ears. Maybe it's an issue with the stock rotors Honda provides with the bike? So if you can find a set of decent rotors from salvage off another bike, maybe that will work. If so, what other rotors will fit the 919? A CBR? Some other Honda?
ThaddeusVenture is offline
post #10 of 18 Old 08-12-2009, 03:05 PM Thread Starter
so here is what i did which seems to be working so far. removed the calipers and pads cleaned all the parts thoroughly with break cleaner paying special attention to the pins and caliper bolts , make sure you clean all the old locking agent. clean and lightly sand break pads using a flat sanding block. check the wheel and axle for alignment . put every thing back together and torque to spec . squeaking has been reduced significantly to the point that I no longer notice it , considering that my breaks sounded like the breaks on a school bus before
post #11 of 18 Old 08-12-2009, 06:20 PM
short bus?? or the regular long bus??
post #12 of 18 Old 08-18-2009, 03:26 PM Thread Starter
what is the difference . and don't say one is longer
post #13 of 18 Old 08-18-2009, 03:38 PM
So, you're a human...
adamjayp's Avatar
"Short Bus" is generally used to reference the bus for handicapped kids. Less politically correct, the stupid kid bus. Not sure how that affects the sound of the breaks, but there it is.
adamjayp is offline
post #14 of 18 Old 08-18-2009, 03:44 PM
....ummmm.......... the short bus usually has more nose and drool marks on the windows.....
post #15 of 18 Old 08-18-2009, 06:25 PM
Gets censored
i rode the piss out of mine and it stopped around 11k............ annoying until then though
brian is offline
post #16 of 18 Old 08-19-2009, 05:23 AM
oldguard60's Avatar
I have always used some silcone stop squeal between the piston and pad. You can get it at any auto store for about $5.00. All it does is to damper the vibrations of the pads.
oldguard60 is offline
post #17 of 18 Old 08-30-2009, 09:43 AM
Guzzi Man
Get a scotch brite pad
Clean the rotors vigorously with one of these and some rubbing alcohol or brake cleaner spray can. Verify you have the retainers that the pins compress correctly installed. You'll get it right, I got faith !
mikestib1 is offline
post #18 of 18 Old 08-30-2009, 04:10 PM
It's like... ya know?
Husky's Avatar
x2 from the time I bought the bike with 3800 to the time I rolled 15,000 or so, it made that noise. Out of the blue, it stopped. I just did new pads(EBC I think) and it hasn't come back.
[insert overly political message here]
Husky is offline
