Speedo Miscalculation - Wrist Twisters
post #1 of 12 Old 03-20-2013, 06:50 PM Thread Starter
Ride with grace.
Devin4242's Avatar
OK, I've searched through the threads, and while I've seen comments on speedometer innacuracy on the 919 (corrected by a 17/44 sprocket upgrade), I have yet to find details on what that innacuracy is, exactly. The only thing I notice is that I think my registered speed on the speedo may be more than what I'm actually doing. Can anyone enlighten me? My speedo says 37 and the oft-seen radar warning signs, the portable ones they put in school zones, generally, indicates 33 range....
Thanks in advance!
Devin4242 is offline
post #2 of 12 Old 03-20-2013, 08:12 PM
With stock gearing my speedo read high vs GPS. At 60 mph on the GPS my speedo read 65 mph. Seemed a little more accurate at lower speeds.
post #3 of 12 Old 03-20-2013, 09:36 PM
The faster you go, the more inaccurate. With the 17/44, at 72mph on the gauges the GPS shows 70.
post #4 of 12 Old 03-21-2013, 06:00 AM
"CERTIFIABLE"
Ken Phenix's Avatar
On my first road trip I compared the 919's cluster to a gps speedo ap and found the speedo reads a constant 11% high while the odometer registers only 3% high with stock gearing.
Ken Phenix is offline
post #5 of 12 Old 03-22-2013, 05:47 AM Thread Starter
Ride with grace.
Devin4242's Avatar
Awesome, thanks. Sounds like the 17/44 helps, though, and from what I hear softens the upper range buzz. Which I don't mind generally, but on longer trips it might be nice to calm down a bit. Or slow down, which is hard to do....
post #6 of 12 Old 03-22-2013, 06:09 AM
oldman's Avatar
I just put a 17 tooth on front on my 2007 919. The chain and back sprocket are stock still. The speedometer was off 7 miles per hour at 70 when compared to my GPS when I had the 16 tooth on front sprocket. It is as near as I can tell 1-1/2 - 2 mph off now (shows 68-69 on bike speedometer when GPS shows 70.) The Bike Still work great for me from dead stop all the way thru gears and is a little less "buzzy ". It is tacking approximately 400 rpm less at 70 mph. I like it better . Just my 2 cents..... Lew
oldman is offline
post #7 of 12 Old 03-22-2013, 09:17 AM
With stock gearing the bike reads approximately 7-8% (depending on rear tire size) optimistic at freeway speeds.
post #8 of 12 Old 03-22-2013, 09:51 AM
Shells 919 at 80 on the GPS was reading 92 on the speedo
Bobby is offline
post #9 of 12 Old 03-22-2013, 10:18 AM
You abused her bike by going that fast? Sheesh Bobby!
post #10 of 12 Old 03-22-2013, 10:48 AM
This is why you get in trouble...
post #11 of 12 Old 03-23-2013, 10:10 AM
There is a slight chance that HER Speedo may have seen the other side of triple digit and that with no proof that she could come up with could have been from a quarter mile street run with 5 miles on her bike
Bobby is offline
post #12 of 12 Old 03-23-2013, 01:58 PM
yup this is what i found... about 8% high (70 indicated, 65 actual) but odometer is spot on. Typical of Japanese bikes. Personally i like it this way... its saved me from a few tickets... and knowing the actual mileage i have traveled is nice.
