Soft dropped bike, oil question - Wrist Twisters
post #1 of 46 Old 09-06-2012, 07:34 PM Thread Starter
I'm fairly new to motorcycles and I'm a mechanics ignoramus and I recently bought a 2003 919. I love the bike but the 2nd day I had it, I stalled out at an up hill stop sign and ended up soft dropping it. I broke the left mirror off and ended up with a small dent in the fuel tank where I tried to hold it up with my knee.
I got the bike up and the oil light came on and it wouldnt start for a few minutes. I drove the bike home and I've driven it quite a bit since.
Now almost a week later I go out for a quick spin and as I pull back into my garage the bike dies and the oil light came on. I checked the oil and couldn't see any in the window. I put 2 quarts in before I saw any in the window. As far as I remember, the oil was full when I bought the bike and it hasn't leaked.
Would a lay down cause the oil to disperse or something? I'm confused how it took so much oil.
Thanks!
friartuck is offline
post #2 of 46 Old 09-06-2012, 07:38 PM
doesn't speak for me
Orange's Avatar
Step 1: You're checking the oil with the bike straight up and down, not on the center stand, and not running; correct?
If the answer to step 1 is yes.
Step 2: drain the oil making note of the amount that drains. If it's low then you need to diagnose where the missing oil went. If it isn't, refill and ride.
The places my 919 has taken me:
Orange is offline
post #3 of 46 Old 09-06-2012, 09:24 PM Thread Starter
Well, I was actually checking the oil with it on the kick stand, but it was definitely low. I checked the oil after filling and when I stand it straight up the oil level is above the high line so I overfilled.
I'm not sure about the easiest way to drain oil but I'm sure I can find it in the manual or something.
post #4 of 46 Old 09-06-2012, 09:36 PM
Check the oil while hot and give the oil 5 mins to settle. Then check the level upright, not on the sidestand.
17mm bolt close to the kickstand is the drain bolt. Snug on the bolt when you tighten it up, usually I finger tighten and do a 1/8 to 1/4 turn with the wrench.
post #5 of 46 Old 09-07-2012, 11:03 AM
Too much! You need to drain your oil and re-add only the specified amount, measured while VERTICAL in the Oil glass.
Look here for owner's and service manuals : https://www.wristtwisters.com/forums/...ners-1209.html
post #6 of 46 Old 09-07-2012, 12:49 PM
a small handheld mirror will help you check the level while you straddle the bike...It can seem a little scary to try to balance the bike while kneeling on the ground to look at the little oil window.
To get extra oil out, try a turkey baster.
post #7 of 46 Old 09-07-2012, 02:35 PM
Fan of Nude Motorcycles
RVAniner's Avatar
I check the oil level every week. I squat down, pull the peg area towards me and hold the handlebar(while locked) to look. I've gotten pretty good at determining where straight up and down is and by having someone verify when holding.
But DEFINITELY make sure when filling that it is perfectly straight up and down. The level in the glass can vary significantly by little movements. And DEFINITELY make sure you don't measure on the side stand as even my full bike has zero in the glass on the side stand.
Hope all is okay! Welcome to the 919 club, they're fantastic bikes.
RVAniner is offline
post #8 of 46 Old 09-07-2012, 06:28 PM
lets make this easy for ya.
Drain oil.
Change filter.
Buy 1 gallon of oil (amazing how rotella t 15w-40 comes in 1 gallon jugs)
Pour entire 1 gallon jug into 919....
DONE.
Note... the 919 calls for 3.78ish quarts of oil with filter... 4 quarts (1 gallon) will not harm it in any way.. the extra couple of oz is minimal.
post #9 of 46 Old 09-07-2012, 06:33 PM
Drain oil.
Change to extended filter.
DONE and filled just above the halfway mark sweet spot
fixed it for ya
post #10 of 46 Old 09-07-2012, 07:54 PM
fixed it for ya
even better!
extended filter being? (i personally run hi-flo filtro HF204's ... standard replacements for the OEM HONDA only cus i get em super cheap)
post #11 of 46 Old 09-07-2012, 10:00 PM
NWTB Non Stinky 919
jeffie7's Avatar
You could loosen the oil filter until oil starts to come out. After it stops dripping tighten it up again, fire the bike up let it run for 10 seconds, turn it off, and check the oil level. Repeat until its at the correctly level. Just make sure you inspect the rubber oring on the filter. Ive never torn one but I always inspect it.
jeffie7 is offline
post #12 of 46 Old 09-08-2012, 07:10 AM
Drain oil.
Change filter.
DONE.
Do you know how much gas you can buy with that extra 1/8 of a quart. That's about 2 gallons of gas over 10 oil changes which is a lot of wheelies coming out of the snake.
post #13 of 46 Old 09-08-2012, 07:17 AM
hahahhahha
but you see... 1 i am cheap, 2, i like to be efficient ... 10 oil changes at 3.5k mi a piece is 35k miles... at my current riding thats about 4 years of riding
Yall are just jealous that soon when that awesome fluffy white stuff starts falling hard core this season due to el nino, that on the days im not on the snow skis ill still be riding the 919 in the canyons! It is then when i whip out the go pro and make vids for you winter folk.
post #14 of 46 Old 09-08-2012, 07:53 AM
You're damn right we are LOL
Actually I ride in the winter if it's above 35F. Heated gloves and jacket liner help.
post #15 of 46 Old 09-08-2012, 12:25 PM
ricard rides in -35.
post #16 of 46 Old 09-08-2012, 12:33 PM
He also goes really fast in traffic.... Ridiculous fast
post #17 of 46 Old 09-08-2012, 01:35 PM
Hastatus Prior
TheBeeDeeGee's Avatar
This is definitely the easiest way to drain excess oil. I overfilled once before and used this method to get it out. That sight glass is very sensitive to lean angle, if you can get someone to sit on the bike and check it that way. I usually just grab the handle bar and peg and stand it up while I squat beside the bike.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #18 of 46 Old 09-09-2012, 07:01 PM
That man is insane.
post #19 of 46 Old 09-09-2012, 09:23 PM
Hey now guys. Let me set the record straight here. I don't ride in -35. I'm willing to ride in -15C (5F). And I don't go ridiculous fast in traffic either. 100mph isn't ridiculous, is it? Well maybe for an older guy but it sure is fun.
post #20 of 46 Old 09-10-2012, 02:03 AM
... wheelies coming out of the snake..
Jeezum Criminy, Mike, u got wheelies comin' out of The Snake?!? Man, I'd see a specialist about that real quick...
Or apparently [according to A Reliable Web Source] you can home-fix it, by soaking said snake in a glass or two of transmission wine....
K1w1Boy is offline
post #21 of 46 Old 09-10-2012, 04:20 AM
Turns out it was bad oil...
post #22 of 46 Old 09-10-2012, 10:03 AM
hahahahahhahahahahhahahah
post #23 of 46 Old 09-10-2012, 10:48 AM
It was more than 100... AND in 4th of July weekend traffic LOL I'm still shocked we were able to make that run in so little time
post #24 of 46 Old 09-10-2012, 03:36 PM
Shhhh. The cops are still looking for me out your way. It was fun, even though I had to watch my mirrors to make sure I didn't lose you. I'd like to do more rides with you again sometime.
post #25 of 46 Old 09-10-2012, 04:27 PM
i smell another pvster / googlit style bromance brewing!
post #26 of 46 Old 09-10-2012, 08:56 PM
Says stalker ski-lift dude lol
post #27 of 46 Old 09-10-2012, 10:54 PM
post #28 of 46 Old 09-11-2012, 12:02 AM
All he can think about lately is the "snow that's comin'", lol...
post #29 of 46 Old 09-11-2012, 01:14 AM
So, bad snake oil, then?
K1w1Boy is offline
post #30 of 46 Old 09-11-2012, 07:16 AM
StormSurfer
Whiplash97's Avatar
Ok 2 questions: #1 "soft drop"? Vs what!? A not so soft drop? So a hard drop must be like when the gsxr topple off of the fully extended bike lift, ouch!
# 2 - snake oil?
:buell:
Whiplash97 is offline
post #31 of 46 Old 09-11-2012, 12:40 PM
StormSurfer
Whiplash97's Avatar
Check your air box, whenever I flip a quad the oil goes there
:buell:
post #32 of 46 Old 09-12-2012, 01:23 AM
Originally Posted by Whiplash97 View Post
# 2 - snake oil?
Well, if you have to, but a couple of glasses of transmission wine first...
K1w1Boy is offline
post #33 of 46 Old 09-12-2012, 11:03 PM
If that don't do it, muffler bearings will.
84interceptor is offline
post #34 of 46 Old 09-12-2012, 11:36 PM
StormSurfer
Whiplash97's Avatar
???muffler bearings???
:buell:
post #35 of 46 Old 09-12-2012, 11:50 PM
What kinda blinker fluid do you guys use?
post #36 of 46 Old 09-13-2012, 12:28 AM
StormSurfer
Whiplash97's Avatar
What the hell kind of bikes are you guys riding!!?? Sounds like they would be a pain in the ass to do maintenance on!
:buell:
post #37 of 46 Old 09-13-2012, 01:34 AM
...wait till you hear what it's like to do a trail-side powerband replacement on a 2-stroke enduro bike...that's if you're carrying a spare, of course.
K1w1Boy is offline
post #38 of 46 Old 09-13-2012, 02:00 AM
StormSurfer
Whiplash97's Avatar
Ok this is just crazy talk!
:buell:
post #39 of 46 Old 09-13-2012, 04:18 AM
I use Kale Synthetic, good stuff.
post #40 of 46 Old 09-13-2012, 05:11 AM
Looks like good stuff!
