Sato passenger pegs - how to let them down? - Wrist Twisters
post #1 of 7 Old 07-28-2012, 10:35 AM Thread Starter
I'm stumped by passenger pegs!
Never rode anyone on the 919 before, my nephew wants to ride with me, and I can't figure out how to get the pegs down. I pulled, twisted, tried to take them apart, got nowhere. Went to Sato's website, there are no instructions and no parts diagram.
There's small holes on each side of the bracket/joint, so i stick a small alen wrench in it, can tell there's a spring doing something, but was able to accomplish nothing. Took the joint bolt out, the peg won't come off, looks like a sleeve in the joint and I didn't want to drive it out, so I left it alone.
I know this has got to be simple, so someone clue me in.
Thanks!
Clueless
Bullet 919 is offline
post #2 of 7 Old 07-28-2012, 12:39 PM
It's probably stuck in place is all. There is a ball and detent that retain them in place. All you do is fold them down. You might try and pull the peg away while you rotate it. I say throw some aerokroil at it. PB blaster if you want it to laugh at you. WD40 if you want me to laugh at you.
post #3 of 7 Old 07-28-2012, 09:01 PM Thread Starter
Thanks, They've never been used before, I just didn't want to start pulling and banging on them till I understood how they work.
post #4 of 7 Old 07-28-2012, 09:30 PM
Probably easier to get them off mounted. You selling the passenger pegs? Here comes the vultures...
post #5 of 7 Old 07-29-2012, 05:37 AM Thread Starter
They aren't for sale, I finally need them.
post #6 of 7 Old 08-04-2012, 01:14 PM
There is no detent system. I worked on my today to get the left side to stay in the 'not in use position.' There is a bolt/nut that the peg pivots on, this also provides the friction to hold them in place. If your peg isn't moving, remove the nut and back the bolt out (it's a locking nut, that does not provide the tension.) Pull the peg off, lube it up, reassemble. Leave the nut off while you assemble it. Tighten the bolt down to where the peg starts to 'catch' as it gets to the closed position. Install the nut and fine tune to your liking.
post #7 of 7 Old 08-06-2012, 03:56 PM Thread Starter
Thanks, I'll give it a try. I tried to dissassemble them, but couldn't get them off, but I was in a hurry. I haven't had time to work on them since. Maybe try again tonight.
