RX2 almost installed - need help! - Wrist Twisters
post #1 of 10 Old 11-02-2012, 06:20 PM Thread Starter
mphoebus's Avatar
Hey all,
I have everything installed and working on the koso rx2 except a couple things. I am going to do a post for what I did on the my bike including 5 3/4 duel headlights, meter and windscreen. But I only have a couple of questions about the speedo.
1 - Can I wire my ground to the ground that comes off the harness? There are 3 Green wires that run together which went to the gauge lights. I was going to wire my ground to that pin on the connector. I just didn't want to run to the frame or to the battery.
2 - I think this has been discussed in prior posts but not clearly. I have a br/blk and blk/brn coming off the old gauge for fuel reserve indicator. It says in the instructions that you could blow the gauge if you wire this wrong. I was going to run the blk/br to the new gauge. Would this be right?
3- Since there are multiple wires for oil and water temp I guess I will have to use the sensors provided?
Here is the connector map I made if it helps.
mphoebus is offline
post #2 of 10 Old 11-02-2012, 06:46 PM
Need money for parts.
ganktor's Avatar
point 1 - yes, 2 seasons of riding wired like this and no issues
point 2 - not sure, never connected
point 3 - you have to use the included sensors. leave the oem ones alone. they feed the ecu with necessary info
ganktor is offline
post #3 of 10 Old 11-02-2012, 06:59 PM
Originally Posted by mphoebus View Post
Hey all,
Attachment 23043
The Black / Brown wire is switched battery voltage for logic power to the original instruments. Applying +12V to the constant current generator that is used to read the fuel gauge sending unit would seriously damage the gauge. In point of fact there is no reason why the Green (Koso) fuel sense lead needs to be connected to anything in this application -- the 919 uses a thermistor to sense low fuel, and it is incompatible with the Koso fuel gauge driver. Connecting it will not damage the gauge in any way, but wouldn't do any good either. If the Green wire is not connected the fuel gauge readout will not be on.
The Brown / Black is the feed from the low fuel sensor in the tank.
post #4 of 10 Old 11-02-2012, 08:07 PM Thread Starter
mphoebus's Avatar
So there is no way to attach fuel sensor?
mphoebus is offline
post #5 of 10 Old 11-02-2012, 09:48 PM
Rob ^^ made a thermistor specifically to work with the 919/Koso combo. The first one is currently with Helimech, but was used by Arctic and myself on the same gauges and worked flawlessly.
Not sure if he made more than one, but a PM to him with some $$ might egg him into making another
post #6 of 10 Old 11-03-2012, 07:29 PM
ganktor's Avatar
Order through his website. Link in his signature.
ganktor is offline
post #7 of 10 Old 11-04-2012, 05:24 PM Thread Starter
mphoebus's Avatar
ok, im a mook. i can't find rob's website...
mphoebus is offline
post #8 of 10 Old 11-05-2012, 03:16 AM
woodyeee's Avatar
He did indeed make more than one....i have one on my turbo bike.
I didnt buy it directly from Rob though as it was already on a bike that i purchased.
woodyeee is offline
post #9 of 10 Old 11-05-2012, 04:29 AM
ganktor's Avatar
http://tharengineering.com/electroni...nstrumentation
Posted all this from my phone. Can't tell if it's still in his signature. Sorry!
ganktor is offline
post #10 of 10 Old 01-01-2013, 11:52 PM
I took these videos a long time ago when installing my Koso gauges - just found them, thought they might help.
I did this because the gauges I received from Arctic were from a 2002 bike, but the harness on my '07 was different, so I had to swap harnesses and move the wires in the harness to match the '02 configuration.
Gauges pin layout for Honda 919 2002 vs 2007 - YouTube
