Runs rough at 4500rpm... - Wrist Twisters
post #1 of 8 Old 03-11-2015, 10:56 PM Thread Starter
Pete
SVCBNZ's Avatar
My hornet has always run somewhat rough at around 4500rpm when not accelerating. Under load she vibrates alot more in that rev range, which unfortunately is what I like to cruise at ideally. However at around 6000rpm shes as smooth as silk.
Is this normal, otherwise what can be done about it other than just riding in a lower gear?
I am considering dropping a tooth on my front sprocket down to 16, has anyone also done this? By the looks of it, I should be able to keep my current chain and rear sprocket...
SVCBNZ is offline
post #2 of 8 Old 03-12-2015, 04:22 AM
crimedog's Avatar
Yes, that's normal for this engine. If I were you I would ride that chain into the ground and then buy a 520 17/44 kit from LDH. Down a front tooth with this bike would be great if you are a stunter but terrible for regular use.
08 DR-Z400SM
WFOATT
crimedog is offline
post #3 of 8 Old 03-12-2015, 04:28 AM
OEM front sprocket is 16. You can lower the cruising RPM by going up on tooth in the front. Popular combo for the 919 is 17 front/ 44 rear, which I run and really like.
As far as the vibes at 4,500 RPM, you may want to check for a cracked exhaust mount under the bike.
post #4 of 8 Old 03-16-2015, 06:50 PM Thread Starter
Pete
SVCBNZ's Avatar
What sort of performance does the 17/44 give over stock?
Il have a look into the exhaust mount, thanks for the help!
SVCBNZ is offline
post #5 of 8 Old 03-16-2015, 07:33 PM
crimedog's Avatar
It increases the gearing from stock, there is no change in performance. This engine has such great torque that it can pull through taller gearing with ease, so you end up shifting less and cruising on the highway at a lower rpm.
08 DR-Z400SM
WFOATT
crimedog is offline
post #6 of 8 Old 03-16-2015, 07:36 PM Thread Starter
Pete
SVCBNZ's Avatar
IMPRESSIVE! Thank you marylandmike.... indeed the exhaust mount was broken... will get it welded and report back if that cured the vibrations
SVCBNZ is offline
post #7 of 8 Old 03-16-2015, 08:04 PM
Glad you found it....just seen several here before that had the issue.
post #8 of 8 Old 03-16-2015, 08:06 PM
Welding it may not do much, it may crack again. There are members here that make reinforcement/repair plates that can be bolted to the broken pieces as a permanent fix.
