RPM not working - Wrist Twisters
post #1 of 8 Old 12-09-2012, 04:14 PM Thread Starter
RPM not working
Anyone know what I should check for if my RPM is not working?
Thanks
ASIANREDNECK is offline
post #2 of 8 Old 12-09-2012, 04:23 PM
Page 19-11 of the service manual has a troubleshooting procedure.
marylandmike is online now
post #3 of 8 Old 12-10-2012, 09:28 AM
John
We might have the same problem.... Mine stopped working back in June, and the shop said that there was essentially no signal coming out of the ECU. I had a PCIII and ignored good advice to remove it before installing a salvaged ECU. I had a working tach for just a few minutes. THEN I sent the PCIII to Dynojet. It was long-since out of warranty and they checked it out for about $25. They said that it had problems but couldn't have cause my ECU problems...
jbbachky is offline
post #4 of 8 Old 12-10-2012, 06:10 PM Thread Starter
Ok I went out and tried to read it.
I put the Multimeter on DCV 10 and the needle went above the V.MA 10.
I have no clue what I'm reading. The Manual says anything about 10.5 V is good signal from RPM wire. So does that mean the digital gauge is bad?
post #5 of 8 Old 04-19-2013, 11:35 AM
lusting over something...
james_kraska's Avatar
I've had the same problem since the bike was dropped two years ago.
My PCIII is reading TPS and RPM, but once running, the tach will drop to zero. The power is good to the gauges as it will sweep when the ignition is turned on.
Any ideas as to what might be loose or need re-soldering? Everything seems in spec based on the FSM...
james_kraska is offline
post #6 of 8 Old 04-19-2013, 11:37 AM
Have you tried disconnecting your PC3 and seeing if the tach works?
post #7 of 8 Old 04-19-2013, 12:21 PM
Tried it, same exact symptoms. upside: I got to clean the underside of my rear cowl.
post #8 of 8 Old 04-20-2013, 08:00 PM
Today I dove even further into the problem. I removed the gauges completely, separated the housing and removed the PCB. Upon inspection, there was no damage to caps or any burn marks. In case there was some invisible dirt, I used an aerosol electronics cleaner and brush over every circuit, cap, and resistor. Once everything dried, I plugged it all back in and still the same problem.
The dials sweep, everything else works perfectly, but the tach isn't registering any change to RPM. Interestingly, when the gauge is unplugged and you manually move the needle, it drops to zero slowly. When doing the same thing to the needle when the bike is running, it snaps back to zero instantly.
Can anyone with more electronics experience help out here?
