Rough idle issue - Wrist Twisters
 1Likes
  • 1 Post By K1w1Boy
post #1 of 3 Old 09-09-2020, 06:06 PM Thread Starter
03whitesnake's Avatar
Rough idle issue
Anyone ever have this issue? So I’m having problems with my bike at idle up to 3k
Rpms.. after the bike warms up is when I notice This issue. I’ve checked the battery Connection and they were fine as well as the air filter. I’ve even put a can of sea foam in the tank and that seemed to work for about 500 miles and then it comes back again... I even put a new fuel pressure regulator on the bike. Still didn’t fix it. I’ve had the plugs changed about 4,000 miles ago when I had the valves checked. Not sure if it could be a loose wire or maybe bad fuel pump? I’m at a loss here it’s getting quite annoying!! Any feed back would be appreciated!!
03whitesnake is offline
post #2 of 3 Old 09-09-2020, 09:16 PM
A starter valve sync may help. That is if the starter valves are out of sync and causing the rough idle.
post #3 of 3 Old 09-10-2020, 01:16 AM
+1 on the starter valves. Had a huge impact for me. Yuge. You wouldn't believe the impact. No-one's ever seen anything like it. People are saying probably second only to Abraham Lincoln.
robtharalson likes this.
K1w1Boy is offline
