I put a new chain and sprokets on my 9er WEEKS AGO, and have been waiting for my rivet tool to come in, but its on back order and summer is almost over, got to get out riding. I did it with a c clamp and tip from a flare tool. But i have never used a rivet chain link so I am wondering if you guys think this looks ok.
The rivets look flush with the holes, which makes me think it won't hold under power. The rivet tool will crush the ends to kind of flare them - to keep them from backing out. Why not run up to a shop or find someone local that'll let you borrow their tool?
I have been trying, 3 shops in town are a joke, 2 didnt know what i was talking about and the other didnt have one. They are more focused on boats. Have no one to borrow one from but will have to wait if i can not get it with what i have.
odered the tool from a shop in winnipeg and it went on back order, and they never told me until i called today. The "bike" shops here no nothing about bikes, or customer service.
Yeah...that masterlink should get replaced, now. Once a rivet gets cracked or peened badly like that, it will tend to bind up improperly and could break unexpectedly.
once you have a proper chain tool it will be easier to set the rivets properly. The "pro" way of finding out when enough is enough is to use a dial caliper to measure the mushroomed out head of the rivet. IIRC, .030 is the measurement to squish it to.
I think it would be ok to ride gingerly with that, but only until the replacement arrives...I'm not endorsing it, just giving an assessment. If you choose to ride it like that, it's on your head.
Honestly, it's hard to tell what it would do which is the problem. It could be fine for a long time, or it could fail after 5 miles. That's the reason for the strict manufacturer's spec on it...
if you are that hard up for a ride, I know some people think its Taboo, but geta freaking clip link and call it a day... Some people will freak out you cant do that it will fail yada yada... I know I rode about 30k miles on one no issues on my 919 in every condition imaginable...
get a new master link, take the rear tire off (or at least pull the chain off the rear sprocket) so the chain can lay on the ground, place a BIG sledge hammer behind the master, then take a small ball peen hammer and tap on the rivets to mushroom em out... not the proper way but will get the job done just as good (just make sure to not clamp the plate too tight to begin with)
I've actually done it this way many many times. You just have to keep swiveling the chain on it's to make sure you don't get it crimped too tight. The way I did all my dirtbikes including a XR680R that crossed the desert an mountains many time at up to 90mph.
honestly no, its how i have always done my dirbike chains. i do have the tool to press on the side plate properly, then very carefully mushroom out the tips of the rivets.
I tried all the above methods with my master and just ended up making it worse. I finally bought the chain tool and am glad I did. I am sure some of the other methods work but I was uneasy with how it looked. Here's how mine turned out with the motion pro tool.
This may be a little late, but in the meantime put a clip link on it and silicone it in place. It will be better than what you have. For additional peace of mind, wrap the clip link and the plate it's with, with many turns of fishing line before siliconing it. This will ensure that the clip will stay on. Also, one edge of the clip is sharper than the other. Install the sharp edge facing out.
In close to forty years of using clips on my motorcycles, I've yet to have a single one come off, despite horror stories to the contrary of how dangerous they are. Clips only come off if the installer puts them on incorrectly, and there are many ways of doing just that.
Not a whole lot publicity for EK screw types, but it works just like a rivet link. The screw portion is just for installation and doesn't actually hold the link in place.
I've never used it but it seems the VFR guys are getting good reviews from it. Chain Master Links - VFR Discussion
There's a guy on that thread that said he was able to use it with a DID chain as well.
This is an older thread, you may not receive a response, and could be reviving an old thread. Please consider creating a new thread.
Related Threads
Sportbike Forums on WristTwisters
678.5K posts
10.2K members
Since 2006
A forum community dedicated to all sportbike owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
