Replacing the engine in a 9er - Wrist Twisters
post #1 of 6 Old 10-13-2017, 11:52 AM Thread Starter
Casingninja's Avatar
Are all year 9ers engines interchangeable? Looking to buy another to replace my existing engine that got hit by a car.
Thanks for the input!
Casingninja is offline
post #2 of 6 Old 10-13-2017, 01:07 PM
Yes all Honda 919 engines are the same
post #3 of 6 Old 10-14-2017, 06:34 PM Thread Starter
Thank you, LDH. I was looking at engines, then told to enter my vehicle info after which it said an 2004 engine was not compatible with my 2007. Double checking. Thanks again!
post #4 of 6 Old 10-14-2017, 07:53 PM
If you want some added assurance, do a P/N check of the ECU for the two years.
They should be the same.
Also. The 07 has a catalytic converter in the base of the Y Tube ahead of the twin exhaust cans, and the 04 doesn't. But neither have any electronics or sensors on the entire exhaust system, and the headers, Y tubes and cans are all interchangeable on an independent basis (as in full mix or match interchangeability).
post #5 of 6 Old 10-14-2017, 09:48 PM Thread Starter
@mcromo44, then you for the additional information, I will be sure to use it!
post #6 of 6 Old 10-14-2017, 09:50 PM Thread Starter
And I am wanting to go to a low mount exhaust so I will be looking up info on the 900rr header swap.
