replacement throttle tube..are they all the same? - Wrist Twisters
post #1 of 3 Old 09-27-2012, 10:12 AM Thread Starter
dieselndixie's Avatar
long story short...the PO glued heated grips onto the bike. I have replaced the bars, but cannot re-use the throttle tube because the heated grips are hard grips, and they are glued on.
I need to get a replacement throttle tube....do I need to go to the dealer? or will your basic motion pro throttle tube work? the honda parts diagram hasnt been very insightful
dieselndixie is offline
post #2 of 3 Old 09-27-2012, 11:11 AM
Tire abuser
prtsimmons's Avatar
Motocross grips and throttle tubes are shorter than street grips and throttles. The Motion Pro might be an MX throttle tube - you could use it, but you would have to use shorter grips and move the throttle/ switch housing toward the end of the bar (or have your bars hanging out the end of the grips). If it's a dual-cable Motion Pro throttle tube for a honda street bike, it will probably work fine.
prtsimmons is offline
post #3 of 3 Old 09-27-2012, 11:52 AM Thread Starter
awesome...its a street tube.
