Removing stripped screws/bolts - Wrist Twisters
post #1 of 8 Old 07-18-2009, 05:21 PM Thread Starter
UJM
Banned
Phillips head - sometimes even the impact driver will round them out, as mine did.
Couple suggestions, make sure you have the right bit and you might want to try a touch of valve lapping compound on it to help it "bite"
But, sometimes they strip, and here is one way that I have used successfully over the years.
Tools: A hammer and a pointed drift
I use the drift to tap the screw loose - works great most of the time!
When it fails, there are other options -
Here was a "difficult" cam bolt on a Porsche 944 -
Sometimes you drill the hole to the proper size, in this case, is was an allen head, so it self-rounded itself to the proper size.
Sometimes, well, sometimes - you get it out -
But it was a little more than you bargained for.....
Other side:
It's nice when you can tap tap tap 'em out.......
UJM is offline
post #2 of 8 Old 07-18-2009, 06:04 PM
Always hated those Phillips head screws. Allen-head replacements were the best solution.
post #3 of 8 Old 07-18-2009, 06:19 PM
I killed Barton664
Basspiece919's Avatar
Maybe this should go in the helpful threads section! Good info!
Basspiece919 is offline
post #4 of 8 Old 07-18-2009, 07:55 PM
What's a 919?
RoboStraub 919's Avatar
Great info UJM!!
To everyone else out there. In my experience with tough/rounded out/rusted on screws DO NOT use a bit called the 'grab it' which is supposedly guaranteed to get out any stuck/stripped/rounded out screw in existence. The bit is nothing but a piece of junk. The 2nd time I used this "foolproof" tool I/A/W the directions it broke off inside the stripped screw i was trying to get out.
Slow is smooth, smooth is fast.
RoboStraub 919 is offline
post #5 of 8 Old 07-18-2009, 08:07 PM
I could use your help to get my chain adjuster bolt out of my swingarm. Got to love that bi-metal bond!
post #6 of 8 Old 07-18-2009, 10:33 PM
919>food>beer
Jeef's Avatar
there is also the dremel slotting it to make it in a regular screw and the impact driver. The rotor screws on my honda Crx's have rounded off many times, the key to them was drill off the head and then the body would just back out with a drill. I tried drilling straight through and using a easy out, till it broke off, You ever try to drill through one of those things? they are friggen horrid!
Jeef is offline
post #7 of 8 Old 07-19-2009, 04:51 AM
Left handed drill bits. If you have to drill you might as well use them.
post #8 of 8 Old 07-19-2009, 10:25 AM
Ah, you arent a real man unless you can take a torch and melt out the stuck bolt and leave the real threads intact.
