Relocating rear turn signal help - Wrist Twisters
post #1 of 7 Old 06-24-2017, 07:43 AM Thread Starter
Hey guys! I hope this post gets some advice because I have a trip coming up and I am a bit stuck.
I am not super mechanically inclined, because this is probably easier than I am making it out to be.
I am trying to install the givi tubular side case racks on my 919er. Its bone stock other than I have the top case mount on it already.
In order to install the side racks I need to move my rear turn indicators up to underneath the top-case rack, and I don't know how to do it!
Do I need to cut the wires leading into the indicator bulb? Or do I need to get at the wire from where it enters my tail cowling..
If anyone has done this before and can briefly explain the easiest way to do it I would be very grateful! Thank you!
I can post pics if this is too confusing.. lol
soybomb is offline
post #2 of 7 Old 06-24-2017, 08:50 AM
Serial Monogamist
ST-DocLizard1's Avatar
Total Awards: 21
IIRC, there was no wire cutting or splicing when I added the Givi monokey side racks and relocated the turn signals. Simply a plug and play operation. I'll try to get some pics for you after office hours today.
Doc
ST-DocLizard1 is offline
post #3 of 7 Old 06-24-2017, 09:05 AM Thread Starter
I've heard people say that but I can't figure out how to do it - would I take the seat cowl off again and get at the wire from under there?
soybomb is offline
post #4 of 7 Old 06-24-2017, 03:19 PM
I'm 99.9% sure I didn't have to cut any wires when I installed the racks. Try searching online to see if you can find the Givi instructions.
post #5 of 7 Old 06-24-2017, 04:24 PM
Serial Monogamist
Total Awards: 21
Yes, the rear cowl has to come off in order to access the turn signal disconnects and then run the wires along the inside of the top box arms and down in between the rear cowl and shovel(rear fender). You don't need to cut any wires or splice into any. Just disconnect the turn signal leads, re-route them, and then reconnect. They will be just long enough if done correctly.
This is providing you have all the parts and a box stock bike with the rear shovel and no "tail-tidy" or anything like that.
post #6 of 7 Old 06-25-2017, 09:28 AM Thread Starter
Thanks so much for this. I bought the whole top rack + side rack second hand so it was a bit of a pain to even get the top rack on properly, so I feel a little stupid that Ill have to take it all off again to re-route my turn signal wires!
Oh well! I guess it won't be too difficult, just a bit time consuming when I go to do it. Thank you very much for your response + pictures, it really cleared it up for me
Cheers!
soybomb is offline
post #7 of 7 Old 06-27-2017, 04:18 AM
Serial Monogamist
Total Awards: 21
The Givi racks(top & sides) are hard to come by.
A wealth of information lies in this website and many members willing to help out.
Good luck with the installation.
Doc
