Rear wheel bearing issues - Wrist Twisters
post #1 of 8 Old 07-31-2019, 06:47 PM Thread Starter
So I recently purchased the 1744 520 conversion kit and rode that around for a while and decided I wanted to drop one tooth in the front and go to 1644 after installing that I noticed a clunking noise coming from the rear sounds like rear bearing went out so I double checked to make sure the front sprocket was facing right direction with the stamp out I also took the chain off and spun the wheel and made the same noise whenever I release the rear axle Bolt the noise goes away when I have tension on it is one that makes noise seems like I've gone through too many rear bearings in the past few years I made sure the axle is lined up correctly
03whitesnake is offline
post #2 of 8 Old 07-31-2019, 08:14 PM
Too many?
What has the history been like?
post #3 of 8 Old 08-01-2019, 01:56 AM
I did my 17/44 520 conversion a few months ago and when I finished, I had a very odd sound when running on the rear stand. It went away after I cleaned, lubed and lined up as best I can.
If you look at the chain, does it slap around a lot?
I made a video of mine, does your chain sound anything like this or bounce around as much?
Maybe make a video of yours and post it.
Does the tire have any play in it that would indicate a loose bearing?
post #4 of 8 Old 08-01-2019, 03:26 AM
Might not be a bearing.
After I took my 17/44 kit off [after 25,000 mi] the wear on the back of the front sprocket kind of explained the clunking I had been hearing from the chain, and made me think I should have installed the sprocket with numbers facing away from me, ie, into the engine, so that the wider shoulder would have moved the sprocket out, more in line with where the chain seemed to want to be.
The number-out installation of the sprocket put the narrow sprocket shoulder in, and the wider one out.
K1w1Boy is online now
post #5 of 8 Old 08-01-2019, 07:29 PM
Canadian Blue
Mark919's Avatar
Well, If the rear sprocket for the 520 chain is a flat plate with no shoulder offsets for thickness compensation, then the switch from a 530 to a 520 chain puts the chain center-line location closer to the center of the bike (towards the engine). With that - the proper orientation of the front sprocket would be "The number-out installation of the sprocket... the narrow shoulder in the the wider one out."
Just an observation - I hope the logic helps.
Good luck,
Mark
Mark919 is offline
post #6 of 8 Old 08-01-2019, 07:49 PM
nathanktm's Avatar
I made the same mistake thinking the wider shoulder was to face inwards. This was probably the reason why my last chain from the 17/44 kit exploded, along with extreme abuse on my end. The pins all sheared off on one side of the chain, indicating that the alignment wasn't proper. I'm pretty sure that I learned in my last phonecall to kyleracing that the wider shoulder faces away from the bike.
Also, because the chain sat further out, it wasn't properly encased by the metal chain gaurd the front sprocket sits it, allowing my chain to whip into my waterpump and take that out.
Lessons learned hard are lessons learned well I say. Also, I've learned that as chains get older or if they are dry, especially both, they are loud even if aligned properly.
BTW, take everything I say with a grain of salt because I'm one of the few people who actually managed to make a high end chain go boom, i could be wrong still
nathanktm is offline
post #7 of 8 Old 08-01-2019, 08:21 PM
Originally Posted by Mark919 View Post
If the rear sprocket for the 520 chain is a flat plate with no shoulder offsets for thickness compensation....
Always interested in logic Mark, and maybe this was where the problem lay. Sadly, I think I have already biffed the rear sprocket so can't do any retro-investigation, but the attached pics show the unmarked front [outer] of the sprocket, and the wear that occurred behind it when the narrow shoulder faced the cases.
post #8 of 8 Old 08-02-2019, 12:11 PM Thread Starter
so thats my question... do u think that having the front sprocket installed wrong could effect the rear bearings to out bad? i installed th 17/44 conversion and rode about 200 miles with no issues.. i wasnt a fan of it so i dropped -1 in the front and after installng i noticed a creeking noise coming from the rear end. i thought maybe the rear bearings went out from putting in the front sprocket wrong... so the wide shoulder should face out? with the #
