Rear sprocket stuck - Wrist Twisters
post #1 of 12 Old 07-12-2012, 04:52 PM Thread Starter
Warped man...
Cheeseburger's Avatar
Rear sprocket stuck
I just spent the last hour and a half trying to remove my rear sprocket. I had the rear tire off and was sitting on it, while pulling with a force equivalent of the Incredible Hulk on the five sprocket nuts. Not one would budge. So I bolted everything back up and gave up.
Am I going to need to find a pipe to slide the wrench into and work it that way? Or is there some critical step I'm missing? I literally removed the back tire, and went to work on the sprocket nuts.
I'm thinking maybe the previous owner threw loctite on them or something....
Does this napkin smell like chloroform? Just kidding baby lemme buy you a drink.
Cheeseburger is offline
post #2 of 12 Old 07-12-2012, 04:55 PM
so your trying to remove the sprocket from the cush drive?
Proper size socket and breaker bar sounds to be in order.
As well as maybe a soak of some aerokroil.... or PB blaster if you cant source the nectar from the gods that is aerokroil.
post #3 of 12 Old 07-12-2012, 04:56 PM
Use an impact gun, or an impact driver. Take the cush out and put it in a vice with soft or wooden jaws. Try and put some heat to it, just stay away from the bearing.
post #4 of 12 Old 07-12-2012, 05:01 PM Thread Starter
Warped man...
I sprayed a bit of chain cleaner around the nuts in hopes it would work, but nothing.
Was thinking of bring out the heat gun too. I think a breaker bar is going to be the ticket. It' not going to tweak anything wrenching that hard on it is it?
post #5 of 12 Old 07-12-2012, 05:04 PM
Are you taking the cush drive out of the rim? If not you are loading up the rubber drive inserts and not getting a good load on the fastners.
post #6 of 12 Old 07-12-2012, 05:06 PM Thread Starter
Warped man...
No, cush drive was still in the rim....
post #7 of 12 Old 07-12-2012, 06:23 PM
Put the wheel back on the swingarm and use the left side arm to hold the socket while loosening the nuts -- the socket will be on top of the arm to loosen, so thoroughly pad the arm with a small block of wood and cloth to prevent scratches and tie the wood / cloth to the arm. They will loosen fairly easily if you have a long enough breaker bar.
robtharalson is online now
post #8 of 12 Old 07-12-2012, 08:37 PM
Impact Gun takes about 10 seconds to remove all the fuji nuts and you can do it with the cush drive still in the wheel.
post #9 of 12 Old 07-13-2012, 12:28 PM Thread Starter
Warped man...
Thanks for the replies guys. Took the sprocket off at a buddies house. Put a length of tube across the swingarm and through the rim, loosened each sprocket nut while tire was on with a breaker bar he had. HAVING THE RIGHT TOOLS MAKES LIFE SO MUCH EASIER. After we popped the tire off, had the spockets replaced and tire back on in about 10 minutes. Once I'm out of school and have some cash I plan on upgrading from my 104pc Craftsman set....
post #10 of 12 Old 07-13-2012, 02:53 PM
Crotchety Rocket
cmelnick's Avatar
Donation Extraordinary Ride
So true. People either love or hate Harbor Freight tools. I am in the first group, but only for certain tools. All my sockets, wrenches, screwdrivers, etc are Craftsman, but you can get a perfectly fine 18" or 25" breaker bar at Harbor Freight for about $10 which should fit a student budget just fine. Although, your way of having friends that have tools is even better!
- Stephen Hawking
cmelnick is offline
post #11 of 12 Old 07-13-2012, 04:54 PM
whats that saying.
Give me a lever big enough and i can move the world?
post #12 of 12 Old 07-13-2012, 06:56 PM Thread Starter
Warped man...
A close riding buddy too. Also my boss at work. He's much more mechanically inclined than I am, so that helps too. Monkey see, monkey do by himself later kinda deal. But yeah I'm definitely checking into the HF stuff. There might even be an old bar in the receiving bay at work I could snag. I do work at Menards... so it would make sense.
I'm just a cheap ass bastard
