Rear Brake Switch and scuffed Satos on 9er - Wrist Twisters
post #1 of 10 Old 03-18-2009, 09:42 AM Thread Starter
So, Satan's our mascot?
SuedeGopher's Avatar
So I'm back from my adventure and have started writing something up as a sort of ride report but I had a few casualties on the trip (well, one may have been before)..
Anyway, rear brake switch doesn't seem to be functioning - I'm wondering if this is something that's been encountered before and if so, if there's something I might be missing as to a culprit. I see a little adjustment by the pedal and moving it either way doesn't make the switch go on - wires looked plugged in???
Ah...and the Satos. Yeah, so I THOUGHT my saddlebags would work alright with the loud buggers, but I now have what effectively looks like a line of polished metal as a result of some rubbing (no scratches or digs in the metal, thankfully). Looks kind of crap, and now I'm thinking I should just try and polish the whole pipe or maybe get some BBQ paint and go black? Anyone else been down this road with Sato's?
Just about to turn 12k on the bike so I'll be replacing the plugs and checking out the valve clearance (no chatter, so I'm guessing I'm okay). Fun never ends.
SuedeGopher is offline
post #2 of 10 Old 03-18-2009, 09:49 AM
just send me your Satos and I'll mail you my stock pipes. Heck...I'll even perform the bafflectomy for you first.
I'm not sure of the finish, but if it is brushed, maybe you could use a light scotch brite pad or something similar to blend it back in.
post #3 of 10 Old 03-18-2009, 09:56 AM Thread Starter
Hadn't thought of that option...
post #4 of 10 Old 03-18-2009, 03:56 PM Thread Starter
No love from the peanut gallery?
post #5 of 10 Old 03-18-2009, 04:03 PM
Should not be too hard to pin down. Does grabbing a handful of front brake cause the rear brake lights to come on?
post #6 of 10 Old 03-18-2009, 04:05 PM Thread Starter
Yep, front brake definitely triggers the light, rear brake does not...so rear switch if the wires look connected to the harness, or is there another harness or some such that might be the root cause?
post #7 of 10 Old 03-18-2009, 04:09 PM
I'm guessing it is either the brake switch(adjustment) or the 2 pin connection might be loose. First try a little more adjustment to allow the plunger to extend more.
post #8 of 10 Old 03-18-2009, 05:25 PM
and post up some pics from the trip...
glad ya'll made it unscratched and upright..
post #9 of 10 Old 03-18-2009, 06:06 PM
Curmudgeon
semi_gray's Avatar
There was discussion on "Brake Light Switch" before.
See if this helps:
Bla bla bla brake light switch bla bla
semi_gray is offline
post #10 of 10 Old 03-18-2009, 09:11 PM Thread Starter
Thanks gents - I'll take a gander at the assembly first, I'm guessing it's Jeff's & Mike's suggestion in regards to the rear setting.
Teaser photo from the trip (really trying to do a good write-up to get an award )
