Rear brake pad replacement.. Help needed - Wrist Twisters
post #1 of 9 Old 09-20-2011, 06:27 PM Thread Starter
undercover919's Avatar
I am currently in the process of changing my rear brake pads on my 919 and I have ran into a problem. Unless I am missing something when you turn the "flat head screw" on the rear caliper it will unveil a 5mm allen head that needs to be removed to replace the pads. I am struggling to get this removed as it will not budge. I am assuming it is standard threaded like the "flat head screw" was. Is this correct? I am putting some penetrating lube on it and will be out for dinner and will come back and try it again. Any input would be greatly appreciated.
Mike
2003 Honda 919
undercover919 is offline
post #2 of 9 Old 09-20-2011, 06:32 PM Thread Starter
here is the "screw" I am referring to.
2003 Honda 919
post #3 of 9 Old 09-20-2011, 06:41 PM
Just checked the manual to make sure, you've got it right, the plug should unscrew to reveal the bolt head.
post #4 of 9 Old 09-20-2011, 06:42 PM
NealC's Avatar
Mike,
Get a 3/8" or 1/2" impact driver (one you hit with a hammer) and hex keys for socket wrenches. These tools are a must have for any motorcycle. One good whack should be enough to loosen up that bolt.
Put a small dab of anti-seize on the threads when re-installing.
NealC is offline
post #5 of 9 Old 09-20-2011, 06:47 PM
Originally Posted by NealC View Post
Mike,
+1 you do NOT want to strip out that flat head locking screw... otherwise bad things will happen.
post #6 of 9 Old 09-20-2011, 06:53 PM
OK I just tried to remove mine to see and it was friggen tight. I used a pair of channel locks on the screwdriver handle to add some torque and it broke loose.
Good luck!
post #7 of 9 Old 09-20-2011, 06:55 PM
like mary said you can use some channel locks and a big flat head.
MAKE SURE its a BIG flat head, im talking one that will span the entire width of the slot... flat heads this size are often too wide for the actual slot, so a file, or angle grinder to take a little off to make a perfect fitting flat head is what i did, works wonders.
post #8 of 9 Old 09-20-2011, 06:59 PM
Just added some anti-seize to mine...
Edit: I did the fronts too.
post #9 of 9 Old 09-20-2011, 07:31 PM Thread Starter
Mike,
I am quickly realizing this. A set of hex key sockets are on my to buy list.
2003 Honda 919
