Rear Brake Caliper - Wrist Twisters
post #1 of 9 Old 08-26-2015, 04:22 AM Thread Starter
Question Rear Brake Caliper
Looking to go with the Gold Rear Brake Caliper on a 02 919
Having trouble locating one.
What other bike rear brake caliper is a direct bolt on for the 919?
Thank you for your time.
AWP34 is offline
post #2 of 9 Old 08-26-2015, 06:29 AM
redline919's Avatar
I believe the Rc51 caliper is the same
redline919 is offline
post #3 of 9 Old 08-26-2015, 06:53 AM
RC and 929/954 calipers look identical but the bleeder and fluid port are swapped from the 9er positions
post #4 of 9 Old 08-26-2015, 01:01 PM
As voodoo says, the caliper casting is the same Nissin part, but the one on the 919 is machined differently than the other bikes that use it. It's unique to the 919 and the other parts won't work properly.
post #5 of 9 Old 08-26-2015, 03:28 PM
Batman
velodesign's Avatar
But....wasnt the 919 a parts bin bike? *sarcastic font* hahaha. We get unique calipers...who knew!
velodesign is offline
post #6 of 9 Old 08-26-2015, 04:02 PM
It's mostly a parts bin bike. After all, the rear caliper technically *is* the same casting as used on other Hondas. It's just that the drilling and tapping is swapped around compared to everything else.
The rotor it uses is also technically different from any other Honda but it's really a slightly differently drilled version of the rear rotor off the 1989-1997 CB-1/CB400F.
post #7 of 9 Old 09-03-2015, 07:24 PM
Batman
velodesign's Avatar
Im just noting someone said unique and 919 regarding a part in the same post, same context.
post #8 of 9 Old 09-05-2015, 02:43 PM
Let's take a look at just how many parts on the 919 came out of a bin as opposed to being made specifically for it.
* An important point: in the context of manufacturing "slightly different" equates to "a completely different part".
"Bin" parts:
-- Engine cases ('96 to '98 CBR900), transmission shafts, and possible clutch assembly. With the exception of first gear all other trans ratios are different. Crankshaft, rods, pistons, valves, and a lot of internal components are outwardly the same, but "slightly different" in alloy or fabrication process.* The cases are slightly different: the upper rear engine mount is a rubber bushed unit, not solid like the 919, and the forward engine mount is not used on the CBR. It is sufficiently similar despite the minor machining differences noted to apply the word "bin".
-- Ignition coils. At least probably.
-- Handlebar switches.
-- Front brake calipers and master cylinder? Maybe. Rotors are an unusual combination of later hub dimensions and earlier rotor diameter. Dimensionally they look the same as the F4i, but the number of spools mounting the rotor to the hub is 5, not 7.*
-- Wheels. At least they look like F4i wheels.
-- Rear brake master cylinder.
-- Electrical connectors.
-- Common electrical components such as relays, fuses, injectors, etc.
-- Handlebar? Maybe an early CB350 or somesuch, but how many would still be in a bin? Damned few.
-- Cush drive hub? Possible.
-- Turn signals.
That's about it. I can't find similar forks or swingarm. Of course the frame and bodywork are unique to the 919. While the frame may look similar to the 599, there are sufficient differences to warrant an appellation of unique.
Yup, it sounds like a 100% parts bin bike all right ... NOT!
post #9 of 9 Old 09-05-2015, 02:50 PM
Front rotor carriers are steel on the 9er where the F4i carriers are aluminum, F4i rotors do work, I've been using them for the last couple years now
