RC51 SP1 Fork and Wheel match - Wrist Twisters
post #1 of 13 Old 09-03-2015, 08:02 PM Thread Starter
Is there any way to match my RC 51 Fork SP1 with my F3 wheel? Thanks for your time.
AWP34 is offline
post #2 of 13 Old 09-03-2015, 08:05 PM
I actually think it's a direct fit - you'll need to fabricate some spacers I believe.
I'll let others chime in who have that exact setup. I know I had a F3 front wheel on the stock 919 forks but with RC51 calipers.
post #3 of 13 Old 09-03-2015, 08:15 PM
I don't think it would be possible but I've never tried
post #4 of 13 Old 09-03-2015, 08:37 PM
NM, looks like it was a SP2 wheel I saw - but the look is similar.
https://www.wristtwisters.com/forums/...9-a-11984.html
post #5 of 13 Old 09-04-2015, 04:59 AM
The bearing/hub diameters are complete different .... also the rotors are way to small on the F3 wheel for the RC51 caliper bracket set up.
post #6 of 13 Old 09-04-2015, 09:58 PM Thread Starter
Will the 919 rotors and calipers work with the RC51 SP1 wheel?
AWP34 is offline
post #7 of 13 Old 09-05-2015, 06:02 AM
Total Awards: 17
no. For the swap you will need rc51 wheel and rotors
zaq123 is offline
post #8 of 13 Old 09-05-2015, 08:32 AM
The 9er rotors will bolt up to the RC wheel but the outer diameter of the 9er rotor is too small (296mm vs 320mm)
post #9 of 13 Old 10-17-2015, 12:11 AM Thread Starter
What are the best replacement internals for the SP1 forks?
AWP34 is offline
post #10 of 13 Old 10-17-2015, 06:52 AM
Total Awards: 17
Ohlins 30mm NIX kit...............you asked about the best
zaq123 is offline
post #11 of 13 Old 10-17-2015, 08:15 AM
I went with new OEM. You won't be disappointed. Not the best but very good.
post #12 of 13 Old 01-12-2016, 12:27 PM Thread Starter
Hi Helimech
Happy New Year! Ok so I have made progress on my 02 919. It is finally in my possession. So I am on my parts gathering mission.
I have purchased a front RC51 SP1 wheel and front fork. My question is which rotor year and model should I use to work with my stock calipers? I am looking at EBC rotors to replace the originals.
I also have the Rear 954 wheel as well. Same question.
Thanks again for your time and support.
Sincerely,
AWP34
AWP34 is offline
post #13 of 13 Old 01-12-2016, 01:14 PM
Any RC 51 rotor will work, only difference was carrier color, I'm not sure if the 954 rear wheel works or not, the CBR900RR is a direct swap. If you're going to go to all this trouble might as well swap to the RC calipers and master too, they really are an improvement
