Questions concerning Modification - Wrist Twisters
post #1 of 5 Old 07-06-2012, 09:33 AM Thread Starter
Question Questions concerning Modification
My 2006 599 is originally a California model.
The Evaporative Emission Canister was removed by the previous owner.
I now have four hoses hanging from the bottom of the bike.
Do these hoses need to be plugged or filtered?
Also I just put a slightly de-baffled stock muffler on the bike, original was too quiet.
The stock muffler had a catalytic converter inline with it.
The new muffler does not have one.
I am assuming these two changes will make a difference in the back pressure, and am wondering if this means I need to change the carb jetting.
Am I okay, or do I need to have the carbs re-jetted.
StuDog is offline
post #2 of 5 Old 07-06-2012, 09:47 AM
Rich
RichT's Avatar
I don't have any hands on knowledge about the 599, but assuming it is more or less the same as a 919:
  1. plug any of the lines that are vacuum
  2. The bike is fuel injected. While you may want to play with the mixture with a power commander, it isn't required.
RichT is offline
post #3 of 5 Old 07-06-2012, 10:25 AM
doesn't speak for me
Orange's Avatar
I would plug the lines, or follow them up, remove the lines and cap the ports they are connected to. (Edit: And I would be argued with by 50% of owners according to the post I found below.)
As far as the carburetor, that's going to depend a lot on the exhaust, elevation, and how the carbs are currently jetted. So.... maybe?
Quick google search brings up this: http://www.honda599.com/forums/showt...?t=4312&page=2
The places my 919 has taken me:
Orange is offline
post #4 of 5 Old 07-06-2012, 11:16 AM
All US market 599's are carbureted, both 2004 and 2006 models. Just removing the smog equipment will not necessitate a rejetting of the carb. I even installed an aftermarket exhaust on my 04 and it ran fine with the stock jetting, they're set rather rich from the factory anyway.
Superduke
R1200GS
XR650L
post #5 of 5 Old 07-06-2012, 09:02 PM
Some of those hoses are carb overflow tubes I bet, I would NOT plug those .
Crankcase breather hose perhaps? Trace them back, find out where they go before plugging anything.
