Popping exhaust and bad fuel mileage - Wrist Twisters
post #1 of 24 Old 07-18-2013, 06:27 PM Thread Starter
Hastatus Prior
TheBeeDeeGee's Avatar
So my 2002 VFR is making a "poomp poomp" noise randomly at idle. I noticed it about a week ago at a stoplight and it seems to have gotten worse. I don't seem to be losing power, but my gas mileage was 28 at my last fill up! It also only seems to come from one pipe.
Spark plugs? The bike only has 10k miles, you would think they'd be fine. This is caused by running to rich right?
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
-2006 599 ** WRECKED
TheBeeDeeGee is offline
post #2 of 24 Old 07-18-2013, 06:33 PM
Total Awards: 17
Vacuum leak. Trace which side that pipe is going to and check any vacuum lines on that side TBs
zaq123 is offline
post #3 of 24 Old 07-18-2013, 07:04 PM Thread Starter
Hastatus Prior
So
1. vacuum lines
2. spark plugs?
3. starter valave sync?
or am I over thinking this
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #4 of 24 Old 07-18-2013, 07:12 PM
redline919's Avatar
So
1. vacuum lines
2. spark plugs?
Oil change? Bad gas or running incorrect octane? Has it been sitting? I've put 10k miles on my 9er in the first year I have owned it lol. Does it have a power commander?
redline919 is offline
post #5 of 24 Old 07-18-2013, 07:24 PM
Total Awards: 17
So
1. vacuum lines
2. spark plugs?
I would put "check exhaust headers for leak" at #2. Especially where it meets the block.
zaq123 is offline
post #6 of 24 Old 07-18-2013, 07:25 PM
Canadian Blue
Mark919's Avatar
How about the FPR?
Mark919 is offline
post #7 of 24 Old 07-18-2013, 07:40 PM Thread Starter
Hastatus Prior
I bought it with 7500 miles in March lol, I've put those on since then.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #8 of 24 Old 07-22-2013, 07:24 PM Thread Starter
Hastatus Prior
I couldn't find anything loose with the vacuum lines or headers. You can smell the gas coming out of the exhaust.
A couple of time at the track I had to give it throttle to get it to crank up.
I'm stumped, and I really don't want to have to pay to take it to the shop
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #9 of 24 Old 07-22-2013, 07:28 PM
^screams bad FPR
post #10 of 24 Old 07-22-2013, 07:36 PM Thread Starter
Hastatus Prior
^screams bad FPR
I'll look into this.
Is there anyway to test it, or is it cheap enough to just pick up and replace?
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #11 of 24 Old 07-22-2013, 07:55 PM Thread Starter
Hastatus Prior
Nashville Motorcycle Repair 2003 Honda VFR800 running problem
I just read about failed FPR on 2002 VFR's.
I saw liquid in the throttle bodies when I opened her up. Look like gas dumping in?
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #12 of 24 Old 07-22-2013, 08:01 PM
It's documented elsewhere on here that to check for a bad fpr on a 9er to start the bike and check if the inner headers stay cool while the outer get hot. I'm not sure how this could be adapted to a vfr. Maybe just see if all the headers seem to heat up relatively evenly? I'm sure someone else will chime in with a better idea.
post #13 of 24 Old 07-22-2013, 08:52 PM
rpcraft's Avatar
It does sound a lot like a vacuum leak. Unfortunately I do not know the workings of the 02 VFR fuel setup to help further.
Rob C
2002 DL1000 V-Strom
rpcraft is offline
post #14 of 24 Old 07-22-2013, 10:55 PM
post #15 of 24 Old 07-23-2013, 05:03 PM Thread Starter
Hastatus Prior
Is it possible to open up the FPR and see if the diaphram is busted?
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #16 of 24 Old 07-23-2013, 09:40 PM
Run the bike, rev it and let the throttle snap shut a couple of times.
Shut the bike off then pull the vacuum tube off of the FPR and see if there is any gas in it or smells like gas...
post #17 of 24 Old 07-24-2013, 01:15 PM Thread Starter
Hastatus Prior
I'll try this tonight.
I'm really hoping this is it. It seems to match that post you linked. I could see some fuel in two of the throttle bodies above the butterflies, like what was described.
The weird thing is it runs fine otherwise. Just pops at idle, and has terrible gas mileage. So it would have to be a small tear in this diaphram they mention and not a complete failure.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #18 of 24 Old 07-24-2013, 06:55 PM Thread Starter
Hastatus Prior
OK, thanks a ton nd4 for suggesting to pull the vacuum line to the FPR.
I pulled it, turned the key.....and fuel dripped out. BINGO, bad FPR.
Here are the pics just to be sure I'm seeing the right thing. In the picture you can see the FPR, and I pulled what I am pretty sure had to be the vacuum line, but I want to be 100%.
You can see the port where the vacuum line was at the bottom, with the large hose on the left coming from the fuel tank.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #19 of 24 Old 07-25-2013, 04:55 PM
Yup that's it... And called it... In the quick searching I did on the vfr fpr there were some aftermarket higher pressure ones that aided in better low throttle opening motor operation... Do a lil research on the subject
post #20 of 24 Old 07-25-2013, 05:03 PM Thread Starter
Hastatus Prior
Yeah I came across that as well. I think people installed ones from the Blackbird or something.
I already ordered the stock one, but if I find out some more I may return it and upgrade.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #21 of 24 Old 07-26-2013, 06:30 PM
Canadian Blue
Mark919's Avatar
The FPR for the VFR is a little harder to get at than with the 919. It is a common issue with that bike also. (I sold my VFR last fall and recall all the disassembly required.)
I think my post #6 did call this first - but who's counting... LOL
Mark
Mark919 is offline
post #22 of 24 Old 07-26-2013, 06:53 PM Thread Starter
Hastatus Prior
Mark
Haha, yeah OK guess you did call it first.
What disassembly exactly. Maybe I'm thinking it's going to be simpler than it is. I was hoping the hardest part would be draining/keep fuel from going everywhere when I disconnect the fuel line to the FPR.
-2005 CBR 600 F4i
-2001 RC51 ** SOLD
-2002 VFR 800**SOLD
-2002 919 **SOLD
post #23 of 24 Old 07-27-2013, 01:13 PM
Canadian Blue
Mark919's Avatar
I looked at the VFR service manual again and all you need to do is remove the air cleaner housing to get at the FPR. That's not bad at all but still more work than the 919. (It was the thermostat replacement that required removal of the throttle body assembly on the VFR. That's a bit more work...)
A good forum for information on the VFR is VFRD Home. Good guys and lots of info and repair procedures.
Take care,
Mark
Mark919 is offline
post #24 of 24 Old 07-27-2013, 03:24 PM
its no harder than you already have done op... you have gotten to the FPR it looks like it spins off and you are good.
and yes mark you win this round.
