Pic Request - Wrist Twisters
post #1 of 22 Old 09-27-2013, 05:57 PM Thread Starter
Pic Request
Can anyone with stock front ends please take the following pics & share?
Taken facing the front wheel from the front
1) Right spacer
2) Left spacer
3) Clearance between the left caliper & rotor on both sides
4) Clearance between the right caliper & rotor on both sides
Thanks much in advance.
arshishb is offline
post #2 of 22 Old 09-27-2013, 06:12 PM
Flanged spacer goes on the right (throttle) side, flange facing out against the fork leg
Not sure what you're looking for on the caliper/rotor pic
post #3 of 22 Old 09-27-2013, 06:17 PM
yup. as the other spacer buts up against the larger section of the front axle so no need for a flange.
post #4 of 22 Old 09-27-2013, 06:19 PM Thread Starter
I want to see the distances in relation to the rotor, fork & caliper. My front is closer to the left, that is the clutch side. So much so, that the rotor is just mm away from rubbing the caliper. Not sure what is going on with my front. I have since replaced both rotors, front axle, installed new bearings. Its almost as if the throttle side spacer is too large?
arshishb is offline
post #5 of 22 Old 09-27-2013, 07:35 PM
In order (from front of bike) left caliper, right caliper, left spacer , left spacer farther, right spacer, right spacer farther. Not sure if it's what you're looking for. I can grab some more if you want.
post #6 of 22 Old 09-27-2013, 08:53 PM Thread Starter
Thats it, my flanged spaced is much larger than that! I will take a pic shortly. Wow this must really screw up my forks since they are now pushed out. Thanks Badmoon!
arshishb is offline
post #7 of 22 Old 09-27-2013, 09:59 PM Thread Starter
Here are the pics. The spacer looks quite different from that of Badmoon, unless of course its an illusion The next pics show the difference between the caliper & rotor clearance. The throttle side caliper is very very close to the rotor. In fact, there are rub marks from the rotor on the caliper. The other side's caliper has perfect clearance to the rotor.
arshishb is offline
post #8 of 22 Old 09-27-2013, 10:49 PM
You might just want to try loosening every thing up and trying to get it to seat better. The shape looks the same, mine just looks like it's seated down a little further in the wheel. You can see what happened to my wheel when I put the spacers in back words and tried to tighten everything up in this picture.... Lol what makes you think you have the wrong spacers?
post #9 of 22 Old 09-27-2013, 11:03 PM
how did you go about installing the front tire.
Proper way is to:
Slide axle in from clutch side, with non flanged spacer, wheel, flanged spacer (from clutch side to throttle side), and align groove on clutch side of axle with edge of outer fork (so ~1/4in of the axle is sticking out).
Tighten clutch side pinch bolts. Throttle side pinch bolts are NOT TIGHT.
Thread in axle bolt, and tighten to specified torque.
Tighten throttle side pinch bolts.
Loosen clutch side pinch bolts (yes the ones you initially tightened), and rock the bike back n forth to put the front suspension through fullish movement. This allows to forks to find home and proper spacing apart. Retighten clutch side pinch bolts.
post #10 of 22 Old 09-28-2013, 05:31 AM
It's important to note, the "groove" is circular around the axle, and lines up with the outside face of the fork. When I first heard of a groove to line up it was thinking there was a notch or something that needed to be lined up and I had to spin the axle for it to be in line. It messed me up for like 45 min before I realized I'm stupid... It might be a little difficult to get this to seat if everything isn't lined up right... And torquing it down would probably suck it right anyways, but it's worth checking... Not sure how much that would throw everything off.
post #11 of 22 Old 09-28-2013, 05:35 AM
You can kind of seen the groove in this picture. This is the throttle side axle.
post #12 of 22 Old 09-28-2013, 05:52 AM
I'm guessing that that was how they compensated for the bent axle. And probably bent forks.
post #13 of 22 Old 09-28-2013, 07:35 AM Thread Starter
Ok this is going to be a long post so bear with me, perhaps I should just start another thread with a different title or change the title of this thread.
Anyway here are the order of events that have lead me to this point. Hope it doesn't put you guys to sleep
1) I buy the bike knowing that it has gouged/scratched right rotor. I do not notice any pulsating on my test ride so I didnt give it any thought. I also am aware that it is a crashed bike & most things, if not all, have been repaired. Test ride reveals everything OK with exception of flattened tires due to 30 psi air pressure
2) Bring it home, spend the weekend replacing all maintenance items. Bike feels much better engine wise with new oil, filter & plugs.
3) Go for my first commute. My commute is 110 miles round trip consisting 90% highway. I get my kicks on the on/off ramps but otherwise I am bolt upright for most of the commute
4) it is here that I notice the front pulsating for the first time & I immediately attribute it to the scratched rotor. I start to look out for a replacement & thats when I update this thread. https://www.wristtwisters.com/forums/...wap-29967.html
5) I acquire the replacement rotor & proceed to install it this week.While remove the front axle, I notice that it is incredibly hard to get it out. It just would not budge. I had to hammer it out, used a rubber mallet & even then I had to use a small screwdriver's plastic end to really drive the thing out. I didn't give it much thought then since it was the first time I removed this bike's axle & i thought thats how it is. While installing, same thing, I had to hammer it in. At that time too, I noticed the clearance problem. At this time I was convinced that my axle was screwed up too.
6) Go for a test ride & the pulsating has worsened. My suspicions were true. I order a CBR 600F4i axle off Ebay which shares the same part no. as ours. My dealer couldn't get me a new axle as it was on back order till Oct. I also order a new bearing kit.
7) Once the axle & bearings arrive, I dissemble my front end again. Once I have it apart, I try the CBR axle & it slides right in with NO problems. The bearings were shot too as they wouldn't spin with your fingers. Even with the axle in, they spinned very jerkily. I changed out the bearings & put everything back together following the process outlined in the service manual & I was surprised at how easily the axle went in through the fork, wheel & the other fork. Anyway after assembly, I still see that the clearance is not correct, though marginally better than before.
8) I got for a test ride really hoping that the pulsating has gone but alas no. It is 90% gone but the 10% is still there. It is there as soon as you squeeze the brake lever but once you give pressure it goes away. So here I am & this point I am tempted to change the forks & then the wheel itself.
So, this is why I asked for the pics to see if there is something wrong with my assembly.
arshishb is offline
post #14 of 22 Old 09-28-2013, 08:01 AM
The first thing I would do is get the front wheel off the ground and spin it to see what wobbles, something has to be bent, probably the wheel. did you replace both rotors or just the rashed one? Next I'd pull both forks and roll them on a flat surface. Something else is wrong and you should probably find it and fix it. Lots of parts floating around here on WT
post #15 of 22 Old 09-28-2013, 10:13 AM
That as well as are you sure the bearings are fully seated in the wheel... It looks like the throttle side bearing isn't fully pushed into the wheel causing the flanged spacer to be too far out like in the pics causing the caliper alignment issues.
But also I would check the wheel to make sure its not bent.
post #16 of 22 Old 09-28-2013, 02:56 PM Thread Starter
OK took the entire front end apart. Found the problem, was facing me right in the face.
1) Front wheel is bent for sure on the right side. On my home made wheel rotating apparatus, the right visibly moves laterally when moving the wheel. You dont even need to strain to see it. So this is what is causing the pulsations.
2) The right fork was hit hard from the bottom, this had slightly tweaked the axle hole. The axle can't make it all way & gets stuck mid way. This is the reason for the clearance issue.
The new bearings are seated perfectly, as there is no gap between the bearings & the inner spacer. Of course that is moot at this point as I am going to change my wheel.
What can be done about the forks? I don't want to spend at this point as I have a lot into this bike than I had intended. Cheaper to just change the right lower? Can that even be done? Or go all out & get CBR 600 F4i forks? For that I will have to spend a lot of time acquiring one & then spend on heavier springs. Suggestions?
arshishb is offline
post #17 of 22 Old 09-28-2013, 03:25 PM
Clorox has a FRONT WHEEL
post #18 of 22 Old 09-28-2013, 03:34 PM
Quite a few forks and fork bits on Fleabay too
post #19 of 22 Old 09-28-2013, 03:53 PM
02 Honda CB900F Hornet 919 CB900 Right Fork Tube | eBay
and boom
http://www.ebay.com/itm/02-Honda-CB9...item1e80520f94
Probably be able to do combined shippipng... those forks are CHEAP.
post #20 of 22 Old 09-28-2013, 07:47 PM
02-03 forks are often available cheaply here and on eBay because they aren't adjustable so nobody wants them; I recently gave away a perfectly good set of 02 forks to another member here who needed them after getting minivanned. The 04-07 adjustable forks are a popular no-mod upgrade; the important part for you and your 06 is that you *can* use the 02-03 externals and swap the adjustable 04-07 parts into them.
Front wheels aren't terribly expensive either, and as someone pointed out our member Clorox has a good front wheel for sale for $100+ shipping.
Chances are that right fork stanchion is bent, as is the left (due to what the impact forces sound like). Replace the wheel and I'd suggest snagging both forks just to eliminate any more surprises. You should be able to get away with everything for $2-300 or so.
post #21 of 22 Old 09-29-2013, 08:01 AM Thread Starter
Thanks for the support guys, I am already in communication with Clorox for the front wheel. Just waiting for a total shipped with the wind shield he is selling.
As for the forks, I am going to think about what to do. My long term plan was to replace the forks with that from the CBR 600 F4. I am going to see if I can make these forks work for the next few months till I can save for the CBR front end. I have checked these thoroughly & they are not bent. Glass table test, tape measure test & they pass. I am going to try to tweak that hole to see if I can get the axle through. Once that is done, I wont have alignment problems.
arshishb is offline
post #22 of 22 Old 09-29-2013, 12:18 PM Thread Starter
Here are some pics & videos. You will have to watch the wheel video on full HD to see the rotor movements. Was hard to capture it over the phone camera. Pics speak for themselves, you can see that damage at the bottom of the fork has closed up the gap which prevents the axle the from coming all the way. I am going to try & open that gap.
VID 20130928 173301 441 - YouTube
VID 20130928 173058 383 - YouTube
arshishb is offline
