PCiiiUSB Map Compare function using Difference Table option - Wrist Twisters
 1Likes
  • 1 Post By mcromo44
post #1 of 3 Old 03-19-2019, 08:46 PM Thread Starter
Keep in mind the following before reading further or looking at the documents now in the Dropbox.
The Map Compare function allows you to choose between a “Difference” based Table output, or an “Average” based Table output.
Regardless of which one you select, the Fuel Curves output is depicted in % difference.
So, Map Compare reveals things by three measures, Difference, Average and %.
“(Absolute is a mathematical term, and means there is no + or – associated with the number displayed)
Difference” is actually short for “Absolute Difference”
“Average” is actually short for “Average Difference”.
It is not an Absolute type of number, so the tabled valued can be in + or -.
“%” is actually short for “% Difference”.
It is not an Absolute type of number, so the graph can display both + and – differences.
thegutterpoet likes this.
post #2 of 3 Old 03-19-2019, 09:20 PM
Thanks for the explanation mcromo44.
This winter when I have a spare moment and the inclination I'm going to bust out my laptop and revisit my pc111. Try out some different maps again, check my throttle sync, accelerator pump settings etc. I may tweek a few things here and there. It's been a while since I gave it a good go over.
post #3 of 3 Old 03-20-2019, 08:19 AM Thread Starter
Have fun with it!
Not just the pc111 fiddlin'g, but also the spare moment.
