Oil/oil filter question - Wrist Twisters
post #1 of 62 Old 08-09-2014, 01:41 PM Thread Starter
Todi's Avatar
Gents/Ladies,
What oil/oil filter do you recommend and where I can find it readily available? I have change it previously bought from AdvanceAuto Parts but I'm looking for something better.
Thanks
Todi is offline
post #2 of 62 Old 08-09-2014, 01:48 PM
post #3 of 62 Old 08-09-2014, 02:03 PM
This place has been slow, we need a good oil thread.
Pretty much any oil that isn't energy conserving will work fine. Rotella 15W-40 for me.
Good reference for filters (we are in group 5):
Motorcycle Oil Filter Cross Reference
I used the Supertech 7317 (discontinued) from Walmart, but just used the last one. Gonna switch to Purolator L14610 at my next oil change...just cuz I'm a cheap bastard.
post #4 of 62 Old 08-09-2014, 02:21 PM
Rotela T and a Mighty M4612 filter (cause we have a bunch of them on the shelf at work)
post #5 of 62 Old 08-09-2014, 02:46 PM
I also run the Rotella T ... I buy it in 20L buckets when it goes on sale.
post #6 of 62 Old 08-09-2014, 02:49 PM
I run Honda full synthetic and Honda or Mobil-1 oil filter.
post #7 of 62 Old 08-09-2014, 07:25 PM
morgstang's Avatar
Rotell T6 Synthetic and Napa Gold filter on all 3 of my bikes
morgstang is offline
post #8 of 62 Old 08-10-2014, 01:26 AM
Oil filter possibilities [you choose!]:
ryco Z436
SCA436
Fram ph6607 ph7317
Valvoline vo33 vo5
K & N 204 204c
Purolator pl14612 / 14610/ ML16817
Mobil m1-108 / 110
Bosch 3300 / 3323/ 3320
Wix 51365
Vesrah 4007
Hiflo HF204
Champion COF-104
Repco rof135
Purolator V4612
K1w1Boy is offline
post #9 of 62 Old 08-10-2014, 06:46 AM
Will fly for food.
filipinoaviator's Avatar
Purolator 14610 and Honda GN-4. $25 per oil change every 3k miles.
You can easily pick up the Purolator filter at Walmart for $3.27 and the GN-4 at your local Honda dealership for about $5 per quart (around $25 after tax)
1965 PA-30 Twin Comanche
1985 Kawasaki GPZ900r
1999 Honda CBR1100XX
2005 Honda ST1300
2006 KLX250s
filipinoaviator is offline
post #10 of 62 Old 08-10-2014, 06:57 AM
I use the OEM filter.
I have tried Honda, Spectro & Repsol oils. It might just be a mental illusion but my bike seems to like Repsol.
garyb900 is offline
post #11 of 62 Old 08-10-2014, 04:02 PM
Mobil 1 delvac syn (equivalent to the T6 but smoother shifting according to the butt dunno) and $6 Bosch filter (made by champion, same guys making K&N)
post #12 of 62 Old 08-10-2014, 05:11 PM
Honda919Rider #1
I laugh at people who run anything but the OEM Honda filter. Honda specifications for the bipass valve are specific to the brand and using anything else will harm your engine without question how much so it heavily debated but the fact is the opening pressure of the OEM Honda filter is different than that of every other brand and unless you can prove it with technical documentation from a well known and respected authority then shut your fricken pie hole as you are spitting out more than you are puttin in if you get my drift cowboy now back to the bipass pressure on many of those other filters it may open too soon dumping dirty oil directly into the entire system and if it does not open soon enough you run the very great risk of over pressurizing the oiling system and if you are lucky you will only blow a gasket and if not you might end up blowing something that you will later regret -
wait, that did not sound right.....
what were we talking about?
Steve is offline
post #13 of 62 Old 08-10-2014, 05:14 PM
Originally Posted by Steve View Post
...you might end up blowing something that you will later regret -
TWSS
Fram Filters are actually made by Honda.
post #14 of 62 Old 08-10-2014, 05:19 PM
Just curious how you know absolutely that: "the fact is the opening pressure of the OEM Honda filter is different than that of every other brand"
post #15 of 62 Old 08-10-2014, 05:40 PM
Honda919Rider #1
I used to be the service manager for two dealerships and am Bronze Certified by Honda yes Honda itself that is how and even if that statement was possibly not 100% true how are you YOU YOU going to know which specific filter meets each and every requirement set forth by the great and might Honda!
Sorry, seriously, I know the Honda bi-pass is different than many other filters, to say it is different from every other brand was pure hyperbole....
Steve is offline
post #16 of 62 Old 08-10-2014, 07:05 PM
Batman
velodesign's Avatar
so your saying you followed the manual and over torqued everyones rear wheel on each tire change.
good for you, scotty. given er all u got!
eh, what do i know. popcorn please.
velodesign is offline
post #17 of 62 Old 08-10-2014, 07:18 PM
Yo no sť nada
spyke1019's Avatar
spyke1019 is offline
post #18 of 62 Old 08-10-2014, 10:04 PM
I laugh at people who .... without question ... every other brand and unless you can prove it ... then shut your fricken pie hole ... if you get my drift cowboy .... you run the very great risk of ... if you are lucky you will only blow a gasket .... you might end up ...you will later regret
Find yourself getting in many internet-based conflicts, bro?
K1w1Boy is offline
post #19 of 62 Old 08-11-2014, 06:21 AM
Naw, he usually just gets banned. I use a Wix filter and AMSOIL.
post #20 of 62 Old 08-11-2014, 06:31 AM
StormSurfer
Whiplash97's Avatar
Chevron 20w-50 conventional and a napa filter(same one as my lawnmower and '07+ toyota yaris)
:buell:
Whiplash97 is offline
post #21 of 62 Old 08-11-2014, 06:44 AM
NWTB Non Stinky 919
jeffie7's Avatar
Rotella Dino oil and a Bosch 3030
I'd run a puroletor but I like the black filter.
Just for shits and giggles. How many people here run non OEM filters and have had engine issues? Better yet has anyone run non OEM filters and had a black stone oil analysis done? I've done them for the cars but never the bikes.
jeffie7 is offline
post #22 of 62 Old 08-11-2014, 07:02 AM
rotella t6 and Bosch 3323... damn bosch changed their sticker now though so instead of being a black filter with red letters it has a white sticker on it! now I just peel the sticker off before I put it on...
post #23 of 62 Old 08-11-2014, 07:13 AM
I laugh at people who run anything but the OEM Honda filter. Honda specifications for the bipass valve are specific to the brand and using anything else will harm your engine without question how much so it heavily debated but the fact is the opening pressure of the OEM Honda filter is different than that of every other brand ... on many of those other filters it may open too soon dumping dirty oil directly into the entire system and if it does not open soon enough you run the very great risk of over pressurizing the oiling system and if you are lucky you will only blow a gasket
It would seem to be a very easy test given the proper equipment, which I'm sure someone does. But then again the reason why most diesel oil companies don't even bother getting a wet clutch motorcycle-use stamp, simply just not enough of a market.
I sure as hell hope I'm not over pressurizing or dumping dirty oil in my system..Now you got me second guessing my stuff
post #24 of 62 Old 08-11-2014, 07:16 AM
NWTB Non Stinky 919
jeffie7's Avatar
For what its worth I've heard the same thing for all of our cars and my motorcycle, Suzukis have a weird size filter so even more people are in major fear of messing stuff up.
So far so good.
If you are worried, check out black stone, if the bypass opens too soon, they'll find dirt in your oil, if it doesnt open up soon enough, they'll find worse crap in your oil
Do it for peace of mind and post up the results here.
jeffie7 is offline
post #25 of 62 Old 08-11-2014, 07:36 AM
Bobistheoilguy has a few blackstone results. Only thing is the majority of the guys posting there are ironbutts on cruisers/sport tourers.
What's a blackstone test cost? I've got $5 towards someone who wants to send their well used oil in and post results here (3-5k miles, more the better).
post #26 of 62 Old 08-11-2014, 09:02 AM
Dear Sir,
I strongly suggest you relax and forget about the above mentioned and instead enjoy your ride.
post #27 of 62 Old 08-11-2014, 09:41 AM
Dear Sir,
+1 don't sweat it.
Honda dealerships over tighten the rear axle all the time because Honda tells them to....
post #28 of 62 Old 08-11-2014, 01:11 PM
Their website says it costs $25... I wish I would have read this last week... just changed mine using T6 and a bosch filter with just over 6k miles on it...
post #29 of 62 Old 08-11-2014, 02:30 PM Thread Starter
Todi's Avatar
I'm a cheap bastard too BUT, those cheap darn filters will not work with the stock headers, you lucky bastard.... I have to go with M1-108, darn it
Todi is offline
post #30 of 62 Old 08-11-2014, 02:38 PM
NWTB Non Stinky 919
jeffie7's Avatar
If you're spending in the $7-8 range just go get a Hiflo filter from Honda of Croton. Then head to Wally World for some rotella.
jeffie7 is offline
post #31 of 62 Old 08-11-2014, 04:03 PM
Dear Sir,
Well really that type of worry only occurs when the bike and pilot is at idle. What's really on my mind is if my 55ft lbs setting was good enough for the rear wheel and if my cheapo torque wrench wasn't off... lol
Ok so who wants to be the official WT oil donor of 5-6k mile, preferably diesel oil, for a Blackstone analysis? Maybe I should make a thread...I'll pitch $5 towards your test just for test results to be posted here.
post #32 of 62 Old 08-11-2014, 04:23 PM
I'm game. I'm long overdue for an oil change and my transmission is shifting like utter shit.
post #33 of 62 Old 08-11-2014, 04:48 PM
What oil, mileage, and filter? Best to take the oil after a long ride when you've burned off stuff that can burn off.
Who wants to chip in for PV's analysis?
post #34 of 62 Old 08-11-2014, 04:54 PM
crimedog's Avatar
That's what I've been using for the past 3k miles and my 02 with 32k is quite happy. I wouldn't let Steve's comment worry you.
08 DR-Z400SM
WFOATT
crimedog is offline
post #35 of 62 Old 08-11-2014, 05:26 PM
Those M1-108 are like bling though. I used the Supertech 6607's when I had the stock headers, but they are discontinued. I think Purolator L14612 will fit.
post #36 of 62 Old 08-11-2014, 05:43 PM
Total Awards: 17
I laugh at people who run anything but the OEM Honda filter. Honda specifications for the bipass valve are specific to the brand and using anything else will harm your engine without question how much so it heavily debated but the fact is the opening pressure of the OEM Honda filter is different than that of every other brand and unless you can prove it with technical documentation from a well known and respected authority then shut your fricken pie hole as you are spitting out more than you are puttin in if you get my drift cowboy now back to the bipass pressure on many of those other filters it may open too soon dumping dirty oil directly into the entire system and if it does not open soon enough you run the very great risk of over pressurizing the oiling system and if you are lucky you will only blow a gasket and if not you might end up blowing something that you will later regret - wait, that did not sound right..... what were we talking about?
. Hahaha. Ether you enjoy being a douche or you got funny sense of humor. Maybe both?? Bypass pressure. .. Over pressurizing the oil system... honda Dealership .... Hahahahaha. Well known a respected authority....
zaq123 is offline
post #37 of 62 Old 08-11-2014, 06:06 PM Thread Starter
Todi's Avatar
Mike, L14612 is 3.5" same as PL... , I need 2.5" so I got the "blink-blink" this time, and of course the "wrong" Diesel oil
Todi is offline
post #38 of 62 Old 08-11-2014, 06:19 PM
Oh ok, I was thinking that was the shorter one (TWSS). I stand corrected
post #39 of 62 Old 08-11-2014, 07:23 PM
NWTB Non Stinky 919
jeffie7's Avatar
Be careful the wrong oil and oil filter can cause your wheel bearing to fail.
jeffie7 is offline
post #40 of 62 Old 08-11-2014, 07:33 PM
I ward that off now by torquing the oil filter to 69 ft-lbs.
