ohlins install - Wrist Twisters
 2Likes
  • 1 Post By Superdog
  • 1 Post By CenCO 919
post #1 of 17 Old 02-13-2019, 09:39 PM Thread Starter
CenCO 919's Avatar
ohlins install
I am having issues installing the reservoir as described. I think the reservoir line comes down too straight from the shock. Can i adjust this without jacking things up? just loosen it?
2002 Bandit 1250s
2003 SV650
1995 ZX1100e
2006 919
CenCO 919 is offline
post #2 of 17 Old 02-13-2019, 09:58 PM
Maybe PM LDH or jkraft?
K1w1Boy is offline
post #3 of 17 Old 02-13-2019, 11:00 PM
The Instigator
Ditch's Avatar
Where did you get it from?
2007 919
2003 CBR1100XX
Ditch is offline
post #4 of 17 Old 02-14-2019, 07:32 AM Thread Starter
CenCO 919's Avatar
Cenco 919
Checking with them as well. Hopefully this is me.
post #5 of 17 Old 02-14-2019, 01:08 PM
I have sold over a hundred of the HO-201 and have never heard of this before now so I am hoping it is something simple. You cannot loosen the banjo bolt without losing nitrogen pressure and likely a fair amount of oil in the process.
post #6 of 17 Old 02-14-2019, 02:08 PM Thread Starter
CenCO 919's Avatar
I will give it another shot tonight and see if i can run the line differently. Would be helpful to see a picture of one installed but cant seem to find one, other than the install guide.
Thanks
2002 Bandit 1250s
2003 SV650
1995 ZX1100e
2006 919
post #7 of 17 Old 02-14-2019, 04:13 PM
Not sure if this helps; here's mine. Can't see the angle of the line on the shock, though.
ewmin3m likes this.
post #8 of 17 Old 02-14-2019, 04:22 PM Thread Starter
CenCO 919's Avatar
Thank you, this does still help. Looks good!
2002 Bandit 1250s
2003 SV650
1995 ZX1100e
2006 919
post #9 of 17 Old 02-14-2019, 06:42 PM
Dug up one more old pic. I think the angle of the fitting was the same on my shock.
post #10 of 17 Old 02-14-2019, 08:00 PM Thread Starter
CenCO 919's Avatar
Good news- this was me. The install pics show the line fitting in the plastic tray like the OEM shock- this doesnt work.
Huge Thanks all for sending the pictures- big help.
LDH likes this.
2002 Bandit 1250s
2003 SV650
1995 ZX1100e
2006 919
post #11 of 17 Old 02-14-2019, 08:45 PM
Happy to help!
Sent from my XT1575 using Tapatalk
post #12 of 17 Old 02-15-2019, 11:06 AM
The reservoir on my Ohlins sits in the same location as the stock reservoir, you just have to enlarge the hole so the end can poke through
Sent from my SM-G960U using Tapatalk
voodooridr is online now
post #13 of 17 Old 02-15-2019, 03:40 PM
Not to answer for the OP, but his looks like mine did. The reservoir is in the stock location. The problem that I think we both had was getting the hose to run in the same channel that the stock hose ran. My bike is long gone, so doesn't matter, but I'd be curious to see a setup where it does. Did that allow you to face the sticker out so it can be seen?
post #14 of 17 Old 02-15-2019, 04:15 PM Thread Starter
CenCO 919's Avatar
That was the issue. I was thinking the line should naturally lay the same way as the original, which seems to be the case in the diagram.
Neither the reservoir nor the Preload show the Ohlins sticker facing out, preload i would have had to twist it 180 to get it visible. Oh well.
2002 Bandit 1250s
2003 SV650
1995 ZX1100e
2006 919
post #15 of 17 Old 02-16-2019, 06:22 PM
WERA481
You would have to release the Ni pressure in the reservoir, loosen the fitting just enough to let it swivel and then recharge the Ni.
Thinking of doing that myself actually.
jkraft is offline
post #16 of 17 Old 02-16-2019, 07:36 PM
Here's how mine is sitting
post #17 of 17 Old 02-17-2019, 08:40 AM
Thanks. Looks like I should have asked when I was doing mine! I know I did it that way for a reason, but it's been several years.
