OEM centre stand pics and measurements. - Wrist Twisters
 2Likes
  • 2 Post By Islandboy
post #1 of 5 Old 04-22-2018, 09:52 PM Thread Starter
I just use my OEM centre stand as a service stand. I have cut out the centre of the mount pipe so I can slip it over the exhaust. It mounts on/off in seconds. Looking at it the other day and seeing the service stand samuelc had knocked up, I thought how easy it would be to make your own service stand.
Here are some pics and measurements.
It's made with 25mm diameter pipe.
The mount rod/pipe (A) is 195mm long and 16mm diameter.
The mount pivot pipe (B) is 177mm long and 20mm diameter.
The legs (C) are 300mm long.
The horizontal brace (D) is 160mm long.
Top width centre to centre of leg pipes is 177mm.
Bottom width centre to centre of leg pipes is 200mm.
If I was to make one I'd probably use 25mm box section steel. I'd use two horizontal cross braces and do away with the gussets. One brace in the middle and one down near the bottom.
I'd also probably just use two angle steel pieces to form the mount pivot instead of pipe. Just with 16mm holes drilled in them to take the mount rod.
If you can't cut/weld I'm sure a workshop could knock one up fairly cheap.
ewmin3m and samuelc like this.
post #2 of 5 Old 04-23-2018, 09:27 AM
ewmin3m's Avatar
or just find a super cheap one off ebay :P
ewmin3m is offline
post #3 of 5 Old 04-23-2018, 04:44 PM Thread Starter
Good luck with that.
I did find a cheap one but from a wreckers for 50 bucks.
post #4 of 5 Old 04-24-2018, 07:03 PM
Do you have the spring sizes? Length loop to loop? Pictures maybe on how and where it hooks in. I think these would be rather simple to make. The trick is making it light weight.
samuelc is offline
post #5 of 5 Old 04-24-2018, 08:48 PM Thread Starter
Sorry. Couldn't find spring, think I gave it away. Me thinks your going to make one to stay on the bike? In that case you'll need the bracket it swings up onto. It bolts under bike and has a rubber stopper which the stand rests on when up.
The spring goes on the little loop on the right hand leg and hooks onto the pin on the pivot mount at the bike. Clear as mud?
I think you could make a service stand real easy. One that you keep on the bike a little more difficult but easy as well.
One made out of aluminum would be light.
