Octane - an old favourite - Wrist Twisters
post #1 of 6 Old 04-14-2014, 07:11 AM Thread Starter
mikero's Avatar
I've been using 89 octane for a long time because my mechanic told me it keeps the engine cleaner. It's very expensive here. Is there a definitive answer to this conundrum? Also, is there a difference in octane ratings between the states and Canada?
mikero is offline
post #2 of 6 Old 04-14-2014, 07:30 AM
Octane has nothing to do with cleaning. Octane calculation in US and Canada are different I believe. Here its something like (RON + MON)/2 where as canuckistan uses either RON or MON but not the average of the two, if I am not mistaken. While some fuels may have additional detergents, premium fuel is a waste unless your engine and driving style demand it.
post #3 of 6 Old 04-14-2014, 07:36 AM
There are different octane rating systems.
Generally, the octane characteristics are the same, aside from some local areas.
Denver has lower octane because of the 18 % reduced air density.
Vancouver, for many years, had higher octane fuel available at Chevron.
Sunoco was a later player in Ontario with their higher octane fuels.
All you need is 87.
The main refiners advertise "more cleaner" as you ascend their octane ladder of fuels.
But that is pure hype in my opinion, as long as you are talking main refiners.
87 from a main refiner will be a very high quality gasoline with an excellent additive package including the cleaner component.
What is crucial to understand is that the additive package is added at the tank farm, it is NOT part of the refining process. Some additives will get added at the station, but that is a rarity ( I have personally watched a Chevron driver manually dope a load being pumped into tanks at a Chevron station and discussed the topic).
If an off brand reseller is pumping Shell, Sunoco etc gasoline, you can expect it not to have as good an additive package.
This situation is even worse re imported gasoline, is in off brand sellers buying imported fuel.
Short story, if you want the best cleaner in your gasoline as it is pumped, buy from Sunoco, Shell and Esso branded stations.
And get the least amount of ethanol in the fuel as you can.
post #4 of 6 Old 04-14-2014, 08:34 AM
konigralph's Avatar
Sometimes they'll add in cleaner in the premium fuels is what it means. You can add it in seperately if thats what you're looking for.
konigralph is offline
post #5 of 6 Old 04-14-2014, 01:48 PM Thread Starter
mikero's Avatar
I'm just looking to save money, but not at the expense of my bike which now has 140,000 kms and hopefully a lot more. I just want assurance that 87 is just as good for my bike as 89 nd saving money will be an added bonus.
mikero is offline
post #6 of 6 Old 04-14-2014, 02:02 PM
You have it.
87 is all that is needed.
Buy it from a major refiner.
Be happy.
Have clean injectors and intakes, fewer deposits, no corrosion, full power.
