Niner died tonight - Wrist Twisters
post #1 of 27 Old 12-02-2013, 04:47 PM Thread Starter
deandeib's Avatar
Thumbs up Niner died tonight
Coming home from work tonight, my '07 niner (14.9k mi) died abruptly at an intersection. Engine cranks like hell but no attempt to start except for a brief moment right after I tried to fire it back up. Gas and oil levels are good and bike's been running like a top until tonight. Any suggestions on where to start looking for problems? Fuel pump sounds normal when key is turned on. Any ideas would be appreciated. Thanks guys.
deandeib is offline
post #2 of 27 Old 12-02-2013, 04:50 PM
Battery? Battery cables? Maybe the ground cable underneath the gas tank to the frame?
post #3 of 27 Old 12-02-2013, 04:56 PM
Any codes being thrown by the indicator lights? And +1 to connections, double check the battery connections and the ground lug under the tank. Are the lights turning on as normal?
post #4 of 27 Old 12-02-2013, 05:07 PM
Check your kill switch. Make sure it's working properly as well.
post #5 of 27 Old 12-02-2013, 05:12 PM
I don't think it will crank if the kill switch is off...?
Edit: Nope, just tried it.
post #6 of 27 Old 12-02-2013, 05:15 PM
Nope. The only time one of my niner's cranked without starting, it was bad plugs. Ran perfectly fine one day, wouldn't start the next. That's all I got. Do you have a power commander installed?
post #7 of 27 Old 12-02-2013, 05:36 PM
Order of operations i would do on this.
Check fuses, Check battery cables, Check main ground under tank, check connectors at ECU, Check FPR.
Its going to be something simple... 9ers dont just up and die.
post #8 of 27 Old 12-02-2013, 05:41 PM
+1! To add the Powercommander taps, ground andTPS, (if applicable)
post #9 of 27 Old 12-02-2013, 05:52 PM
Yeah forgot to mention... if you have a power commander and it has caused an issue like this... take it off and sell it for that very reason....
post #10 of 27 Old 12-02-2013, 06:12 PM
Since most of the other probables posted would prevent the fuel pump from running (I.E. a blown ECU fuse or kill switch malfunction) which is not the case, It certainly sounds like the PCIII took a dump. Frankly, I'd follow suit and dump it.
Of course I'd check the connections to it first, but since you have previously posted on the PC cold start problem it seems to be a logical first place to look.
post #11 of 27 Old 12-02-2013, 06:19 PM Thread Starter
deandeib's Avatar
Thumbs up
First of all, thanks to all you guys who responded with ideas so immediately.
In my going down the list of all the suggestions, I found a single light gauge ground wire from the PC to the neg batt terminal had broken off!
son-of-a-bitch! And that damn thing cost me $140 for the tow home but glad it's fixed. Could've been worse though. Could've been out on 95 middle of the night in a downpour. Actually, $160. I give the kid who was driving the flatbed an extra $40 for his NRA membership. He was open carry when he came to pick me up but said he couldn't quite swing the membership dues - now he can.
So, hearty thanks to rmb, nd4spdbh, Rickard919, Pvster, andrewbay1 and any other of the brothers who may be replying even as I write this. Glad to be a part of a great bunch of guys.
Merry Christmas!
deandeib is offline
post #12 of 27 Old 12-02-2013, 06:21 PM
.... another PC3 causing a 919 issues..... another case on my list of "why i will never buy one"
Glad you found the issue... make sure you get a proper wire thats not gonna break off and leave you stranded haha.
post #13 of 27 Old 12-02-2013, 07:45 PM
dur, was thinking of wrong thread when I posted in this one. You guys are right. Sorry about that.
glad you figured it out dean!
ndsp, you JUST bought an Ohlins, FINALLY! We're workin you over. Slowly but surely. we'll have a pool going to see what you'll send your money on next. I bet it'll be the PC3 since you were so vocal about not getting an Ohlins. Look where that got you
post #14 of 27 Old 12-02-2013, 08:03 PM
But see, i never said the ohlins was a bad purchase, just and expensive one... the pc3 yeilds not a whole lot of benefits... and with all the issues the pc3 causes (cold start, random problems, and like above flat out bike dieing) i wont be getting one.
The ohlins only makes the bike better, and wont leave me stranded. hehe
post #15 of 27 Old 12-02-2013, 08:06 PM
Be careful, or that band aid on your tank will fall off and leave you stranded
post #16 of 27 Old 12-03-2013, 12:00 AM
Are PCIIIs that bad or is it how they are fitted that is the problem?
NZspokes is offline
post #17 of 27 Old 12-03-2013, 01:30 AM
Glad you found the problem quickly Dean!
post #18 of 27 Old 12-03-2013, 01:37 AM
Both. They seem to have wiring harnesses that aren't terribly robust and the QC doesn't seem to be very good. The factory recommended install procedure uses methods that all but guarantee future failure. Plenty of threads here about that.
CB700S is online now
post #19 of 27 Old 12-03-2013, 01:40 AM
So best to solder connections on them?
Ive been thinking about getting one.
NZspokes is offline
post #20 of 27 Old 12-03-2013, 02:33 AM Thread Starter
deandeib's Avatar
Been riding the niner almost three years with no issues until last night. PO had the PC already installed. Even with the ground wire detached, it still "looked" OK when I turned on the key, i.e., I saw the usual quick little light show on the column of LED's so I thought it was working. I was pretty sure it was a fuel problem and had good spark too so I was puzzled as to why no error codes Thanks again guys for all the help.
Dean
deandeib is offline
post #21 of 27 Old 12-03-2013, 02:33 AM
The electronics in them seem to be just so-so and fail semi frequently. Thewire connection that attaches to the TPS sensor wire can be problematic, the ground wire can cause problems... after my PC3 took a shit I decided my bike was better off with less than perfect fueling. It wasnt worth it.
post #22 of 27 Old 12-03-2013, 02:36 AM Thread Starter
deandeib's Avatar
I always wondered how it would run without the PC3. Is there an easy way to switch it out temporarily just as a test?
deandeib is offline
post #23 of 27 Old 12-03-2013, 07:12 AM
simply unplug the pc3 from the piggy back harness off the main ecu if im not mistaken
post #24 of 27 Old 12-03-2013, 09:31 AM
You guys crack me up. I've sold thousands upon thousands of Powercommanders over the years. Do you know how many I've actually seen fail since the PCIII USB came out let alone the PCV? About 8...
Generally if there is a problem reported with a Powercommander it is due to an installation error like connecting the wrong electrical fitting (see this a lot with Kawi's) or tapping into the wrong TPS wire etc, but the newer units are becoming less & less reliant on wire taps anyway as they move towards plug & play OEM fittings. A little common sense with the installation can go a long way. If you leave the battery post connector exposed, hanging over the edge of your battery under your seat then eventually it will probably break off and kill the electrical connection. If you have hacked your undertail into pieces and the Powercommander has a habit of falling through the tail section of your bike and gets chewed up by the rear tire then that may also cause a failure Yes that actually happened...
I've also more than once seen some idiot not wanting to spend the money for a unit made specifically for his model bike so he cuts up the harness on an existing Powercommander and tries to wire it in to his new bike. That is a guaranteed recipe for failure and when it does fail he is the first guy on the forum screaming the Powercommanders are crap...
I have Powercommanders personally installed on every Fi bike I own or have owned for over 13 years now and I have never had one single failure.
post #25 of 27 Old 12-03-2013, 09:57 AM
LDH, I guess they help with gas milage? is the best place to mount one in a 919 where they state in the manual? To me it looks a little exposed there.
NZspokes is offline
post #26 of 27 Old 12-03-2013, 10:13 AM
There's lots of room in the tail section under the seat.
post #27 of 27 Old 12-03-2013, 10:44 AM
Remove the worthless OEM tool pouch & put the Powercommander in that slot.
My fuel mileage got worse after installing the Powercommander. The reason being is that my custom map felt so good to my wrist that I started playing up a lot more on the bike. When you get that increased and linear power delivery in your hands it is really hard to ride with restraint.
