New front turn signals - can I just add a ground? - Wrist Twisters
 1Likes
  • 1 Post By Quadiak
post #1 of 6 Old 09-10-2018, 11:26 AM Thread Starter
draco880's Avatar
Hey, I'm restoring a pretty beat up 2002 919, and one of the many things missing was front turn signals. I got a generic replacement pair, which have the two wires. I noticed on Partzilla that the OEM signals have three wires; presumably the green wire is a ground. Can I just do a boring frame-to-ground wire, or would it make more sense to track down some three-wire replacement parts?
Thanks for any advice.
draco880 is offline
post #2 of 6 Old 09-10-2018, 11:53 AM
The three wires on the bike are for indicator, running light and ground.
I changed to 2 wire indicators too, one of the running lights is connected to my headlight to power the halo and on the other indicator itís just insulated to nowhere.
steev is offline
post #3 of 6 Old 09-11-2018, 02:51 PM Thread Starter
draco880's Avatar
Maybe I didn't ask this well, I'm curious if I can just run the ground wire to a ground on the frame, and use 2-wire signals.
draco880 is offline
post #4 of 6 Old 09-12-2018, 08:27 AM
Quadiak's Avatar
Your generic lights have 2 wires you say? If so one wire is a ground, other wire is a 12+ for the bulb. You won't need a separate ground. The factory wiring has three wires because they have a running light as well as the signal. Something a 2 wire generic light won't have.
steev likes this.
Quadiak is offline
post #5 of 6 Old 09-12-2018, 02:27 PM
The ground wire from the turn signal needs to be connected to ground. Thatíll leave you with one wire.
There are kits that put a resistor on the running light wire so you can connect the running light wire + and signal wire + to the other wire on the turn signal. Thatís why I only connected the ground and turn signal wires to the turn signal. You canít complete a circuit properly if you do it the way youíre thinking, and might even damage something in the process when you power the bike up.
steev is offline
post #6 of 6 Old 09-17-2018, 07:06 PM Thread Starter
draco880's Avatar
Awesome, thanks for the information guys.
draco880 is offline
