need some help with rust - Wrist Twisters
post #1 of 12 Old 10-24-2014, 10:17 AM Thread Starter
Garcia242's Avatar
Got a serious eye sore on my 9er's lower triple tree. Anyone know the best way to take care of it? CLR? Emery cloth?
I could just replace it but
it looks like taking it off is a chore.
Thanks.
my name is steve
i live in a box
my favorite color is clear
Garcia242 is offline
post #2 of 12 Old 10-24-2014, 01:19 PM
I've had good success in the past with products that aren't quite a pant - they are some kind of clear liquid chemical preparation that just knocks out the rust.
I'm not in your marketplace, so can't suggest a name, but going on the description, it's likely to be similar to this one:
SMART #3000 Rust Converter & Metal Treatment (formerly Right Stuff) | Sunbelt Chemicals
You'll find something useful if you stick with the words "rust convertor/-er" and maybe "metal conditioner".
You can apply it in really small amounts on specific areas with a kid's paint brush.
K1w1Boy is offline
post #3 of 12 Old 10-24-2014, 02:07 PM
POR-15.
post #4 of 12 Old 10-24-2014, 03:20 PM
Fwiw, at the first sign of rust on mine, I pulled the forks off, masked off the bike, and used a good metal bonding spray paint on them. I went black to match the rest of the bike.
post #5 of 12 Old 10-24-2014, 04:05 PM
dazed and confused
EscapedLabRat's Avatar
This: Evapo-Rustâ„¢ Rust Remover - 1 Gallon
I cannot say enough about this product; it is probably some of the best stuff that I have ever found. It's used by the military extensively, and since it works on ALL oxides, it's got a huge fanbase in gunsmiths for stripping bluing. I'll probably post up a review eventually, but it is some damn impressive stuff.
EscapedLabRat is offline
post #6 of 12 Old 10-24-2014, 04:21 PM Thread Starter
Garcia242's Avatar
Thanks guys. Looks like I can find something to help remove it or inhibit/paint over it. Might paint it a dark grey or something.
post #7 of 12 Old 10-24-2014, 06:29 PM
LackOfCharismaCanBeFatal
vukmang's Avatar
I've used a wire brush mounted on a super fast drill, and than i used a super fine small wire brush mounted on a dremel to have access in those lil holes,,,
than, I've painted it with a rust-oleum spray can,,,its only surface rust, so don't wary unless u live by the proper beach...
good luck!
lack of charisma can be fatal
vukmang is offline
post #8 of 12 Old 10-31-2014, 04:57 PM Thread Starter
Garcia242's Avatar
Ok so took care of the rust problem. First I tried the Evapo-Rust stuff. After about 24hrs of treatment it took off most of the rust on some of the smaller stuff that I could soak. Nut/bolts etc. But on the bottom triple I had to apply it with a soaked paper towel and covered it with syran wrap. It didn'd do much good really.
So I masked off the surrounding parts of the bike and picked up some Rustoleum spray paint. At first I tried a primer that matched the color pretty well. I figured it would look fine. But after it dried it was way too light for my taste. So I used a glossy light gray and it came out great.
Masked up
Initial primer
Darker glossy paint. You can see the difference in color by the darker gray dot on the tape.
Finished product.
I also primed and painted the black cage that routes the wires/cables and mounts the blinkers and headlight. It had a few rust spots and since it's kinda thin AND a pain in the ass to get to, I figured I'd paint it while I had the chance. I painted it a semi-gloss black. I really wish the gray came in a semi-gloss. But I think it all came out ok.
post #9 of 12 Old 10-31-2014, 05:10 PM
vukmang's Avatar
great job.
I've would have done it the same way but was too lazy to dismount the cluster and gauges....
vukmang is offline
post #10 of 12 Old 10-31-2014, 05:37 PM Thread Starter
Garcia242's Avatar
I tried using my dremel to get the rust off. But after breaking a few tips i gave up.
post #11 of 12 Old 11-01-2014, 09:52 AM
Brain stolen again?
Dremels can be pretty mean.
The job looks very nice, Garcia.
Mathew Quigley
post #12 of 12 Old 11-01-2014, 10:56 AM Thread Starter
Garcia242's Avatar
Thanks man. I was probably doing it wrong.
And yes I know... twss.
my name is steve
i live in a box
