Need some help with a VIN #... - Wrist Twisters
post #1 of 11 Old 10-01-2014, 06:52 PM Thread Starter
StormSurfer
Whiplash97's Avatar
So here is the so called lost sheep...
This bike was brought to me by one of my regular customers(we'll call him Dave) in hopes of retrieving the VIN off of it and having it run by the local PD(his son is a Rainier cop) and returning it to the rightful owner if it turns out to be hot....the bike is supposedly own by Dave's son in law that is stationed at fort Lewis and currently deployed in the Middle East
Now trust me this bike would not be in my shop if I in any way thought some wrong doing may be going on and it will not be leaving until I find out the truth to the history of the bike
I just got it today so I haven't been able to look it over much or try to salvage what's left of the numbers but so far I've found that it's somewhere between a 1993-1995 Suzuki RM125
So what I'm asking is if anyone knows a way of recovering the vin numbers? Or were they stamped anywhere else on the bike?
:buell:
Whiplash97 is offline
post #2 of 11 Old 10-01-2014, 07:44 PM
should be stamped into the frame on the neck no?
post #3 of 11 Old 10-01-2014, 08:19 PM Thread Starter
StormSurfer
Whiplash97's Avatar
That's where someone scratched it off, it's pretty rusted there now but I might be able to buff it a little to see some numbers
:buell:
post #4 of 11 Old 10-02-2014, 05:52 AM
SGKukov's Avatar
don't the police have some sort of acid-etching stuff they can use to "raise" a filed off serial number? i think they mostly use it on guns but would be the same application on bike.
SGKukov is offline
post #5 of 11 Old 10-02-2014, 06:38 AM
Lightly buff the area with the finest emery cloth you have to remove rust and paint, then using a bright halogen light set to illuminate the area from as low an angle as possible take several digital pictures of the area with the camera set to as high a resolution as possible. Import the pictures into MS Paint (believe it or not) and you can manipulate the image in several different ways such as color invert, color erase (right click and hold to implement), and paint areas to make the numbers more readable.
If they were deliberately obliterated the application of a semi dilute solution of muriatic acid (pool acid) will etch the area, being less effective where the metal was compressed by the stamping procedure, and will bring the numbers up. This is the method used by police departments on guns.
There is also a possibility that magnafluxing the cleaned area will show the numbers, though faintly.
Good luck.
post #6 of 11 Old 10-02-2014, 06:41 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Lightly buff the area with the finest emery cloth you have to remove rust and paint, then using a bright halogen light set to illuminate the area from as low an angle as possible take several digital pictures of the area with the camera set to as high a resolution as possible. Import the pictures into MS Paint (believe it or not) and you can manipulate the image in several different ways such as color invert, color erase (right click and hold to implement), and paint areas to make the numbers more readable. If they were deliberately obliterated the application of a semi dilute solution of muriatic acid (pool acid) will etch the area, being less effective where the metal was compressed by the stamping procedure, and will bring the numbers up. This is the method used by police departments on guns. There is also a possibility that magnafluxing the cleaned area will show the numbers, though faintly. Good luck. Rob
Thanks rob! I got it and ran it through NICB they said it was clean
:buell:
post #7 of 11 Old 10-02-2014, 08:52 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Now that I know she's clean it's on to the operating table
:buell:
post #8 of 11 Old 10-03-2014, 12:23 PM
carotman's Avatar
What worked the best? Acid? Buffing?
carotman is offline
post #9 of 11 Old 10-04-2014, 02:40 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Just some sand paper then some scotch brite(bear claw) until I got enough of the rust removed that I could make out the numbers, it wasn't ground completely off...not sure what they were trying to do when they scratched on it
...any way I got ur runnin good but the carb just pours fuel, think there's somethin up with the floats, it's got some kind of goofy plastic seat setup for the fuel needle, and the clutch doesn't want to disengage
:buell:
post #10 of 11 Old 10-04-2014, 03:09 PM
I wonder what naval jelly would've done for that rust. Good to hear it wasn't from the spice market.
post #11 of 11 Old 10-04-2014, 11:13 PM Thread Starter
StormSurfer
Whiplash97's Avatar
Spice market?
:buell:
