Need PCIII map suggestions - Wrist Twisters
 1Likes
  • 1 Post By mcromo44
post #1 of 7 Old 08-02-2016, 08:49 PM Thread Starter
Hello fellow 919ers, I need help. I recently bought a 2002 919. It ran fine until I did the baffleectomy, now is spurts and sputters thru all the gears and rpm range. I installed a new power commander iii, and need a map for these mods. K&N insert, debaffled, flap mod. I'm running the 112-005 yoshi type map now and it helped a lot, but it still jerks and sputters up to 3,500 rpm
Gunnerruby is offline
post #2 of 7 Old 08-03-2016, 02:18 AM
Hello and welcome! Did you sync the throttle on the PCIII?
post #3 of 7 Old 08-03-2016, 07:05 AM Thread Starter
i have synced the throttle, it goes thru the rpm range well in neutral. but under load it jerks and over all does crappy up to 3,500 rpm
post #4 of 7 Old 08-03-2016, 08:16 AM
ewmin3m's Avatar
The moriwaki map is one of the best ones on there.
https://www.wristtwisters.com/forums/...map-70913.html
ewmin3m is offline
post #5 of 7 Old 08-03-2016, 10:53 AM
You might want to just try swapping out the K&N filter for the OEM just to see if it corrects the low rpm fueling problem. That has been a known issue for many 919 owners.
post #6 of 7 Old 08-03-2016, 03:07 PM
Just for the hell of it, double check your connections to make sure they are solid. I seem to remember this happening with a loose connection on the PCIII. I'd try the air filter as well.
post #7 of 7 Old 08-03-2016, 05:25 PM
I have never used the 112-005 map.
But the Moriwaki version 4 map is known to be an excellent map for use with a range of good slip on twin can setups on 919s.
I'd be using that as the starting point map, not the 112-005.
Also, in addition to the above suggestions, maybe you have have a corrupted map file or related ill.
Anyway, double check you closed throttle synch, refit the stock filter, check all the PC3usb connections - especially the wire tap connections, and re load a suitable map.
Then see how you make out.
ewmin3m likes this.
