Need Members input "HELP" - Wrist Twisters
post #1 of 5 Old 07-09-2016, 08:51 AM Thread Starter
Zman
Zmanou812's Avatar
The Question I have Is:
Does your bike start when in gear and have the clutch pulled in !
I have checked two 919s and one does and the other does not!
So please ring in ,
Thanks
Zmanou812 is offline
post #2 of 5 Old 07-09-2016, 09:24 AM
So please ring in ,
Thanks
Only if the kickstand isn't down. If your's doesn't when the kickstand is up, check to make sure the two wires on the clutch switch are plugged in (easiest thing to check and they can get knocked off when you wash your bike.
post #3 of 5 Old 07-09-2016, 09:52 AM Thread Starter
Zman
Zmanou812's Avatar
Thanks for the heads up.
after reading I checked and they were plugged in.
So I unplugged and put a jumper between wires,now it starts up in gear.
So I put a continuity gauge on the clutch terminals and I get nothing either way
I pull the lever in and let it out, I assume it is in the lever switch.
I wonder if it's replaceable.
Thanks a ton,
Zman
post #4 of 5 Old 07-09-2016, 06:06 PM
Total Awards: 17
Thanks a ton,
Zman
yes it is. $12, part #35330-413-003
zaq123 is offline
post #5 of 5 Old 07-10-2016, 04:46 AM Thread Starter
Zman
Zmanou812's Avatar
Thanks
I was able to take it apart, Clean the contacts and put Di-electric gell on contact.
Works great and all is well.
Thanks again to everyone
Zman
