Need a little help fixing shift linkage. - Wrist Twisters
post #1 of 26 Old 04-24-2013, 12:29 PM Thread Starter
Man and Machine
Callinmeupward's Avatar
I had broke the head of the bolt to the piece that grabs onto the shifter shaft..
I'm trying to extract the bolt, but the swingarm bracket is in my way.. so I've decided to pull it off but is this a good idea? I went to get a socket to remove the swingarm bolt there but I'm not sure about this and its the only thing holding that left side bracket on. I'd take pictures but camera on phone isn't working.
Callinmeupward is offline
post #2 of 26 Old 04-24-2013, 01:08 PM
Shift linkage is reverse thread on the gearbox side. Snapped it thinking it was a normal nut and bolt?
post #3 of 26 Old 04-24-2013, 01:10 PM Thread Starter
Man and Machine
No the piece that slides on to the shifter shaft..the bolt that holds it on there tight, its head broke off cause I had it in the wrong spot
post #4 of 26 Old 04-24-2013, 01:28 PM Thread Starter
Man and Machine
post #5 of 26 Old 04-24-2013, 01:41 PM
If you take out the swingarm pivot bolt, your swingarm WILL fall, so you need to suspend the rear of the bike first.
Looks like a sticky situation. Honestly, I'd cut that entire bracket off with a mini-hacksaw. Can't be more than $15.
post #6 of 26 Old 04-24-2013, 01:45 PM Thread Starter
Man and Machine
On the swingarm...isnt it just a nut actually on both sides?
I may have been confusing but I'm thinking there is a nut on each side.
post #7 of 26 Old 04-24-2013, 01:55 PM Thread Starter
Man and Machine
Picking up some hacksaws..
post #8 of 26 Old 04-24-2013, 02:08 PM
No, there is an axle. 27mm on the nut side, 22 on the bolt side, I believe.
post #9 of 26 Old 04-24-2013, 02:22 PM Thread Starter
Man and Machine
Ok yep cause the bolt side head is a 22 and that'd the socket..Crap ok..not going any further with that idea lol
post #10 of 26 Old 04-24-2013, 02:49 PM Thread Starter
Man and Machine
Thanks googleit, I had considered hacking it off but wanted to try and avoid buying a new piece but, its off and the teeth are still good at least..
This thread can be deleted if necassary.
post #11 of 26 Old 04-24-2013, 02:52 PM
Maybe some good penetrating oil and a gear/bearing puller might help?
I'd buy another one and cut it off with a hacksaw or a dremel tool with metal cutting wheel attachment
post #12 of 26 Old 04-24-2013, 03:03 PM
Good, wouldn't want to mess up the splines, for sure...
post #13 of 26 Old 04-24-2013, 03:28 PM Thread Starter
Man and Machine
Ok so, now...how many shift linkage parts on eBay will work on the 919..
post #14 of 26 Old 04-24-2013, 03:29 PM
If you have a local honda motorcycle dealer they can usually get it pretty quick
post #15 of 26 Old 04-24-2013, 03:33 PM Thread Starter
Man and Machine
Yeah but it cost more i imagine
Check out this item I found on eBay: http://pages.ebay.com/motors/link/?n...d=380617121824
post #16 of 26 Old 04-24-2013, 04:07 PM
A shifter from an old CB750 fits right on there. The. You have GP shift on the. cheap. You may be able to cut a slot in what's left of the bolt and use a screwdriver to get it out.
post #17 of 26 Old 04-24-2013, 04:09 PM
You need to go OEM so you at least get the right spacing.
Part # 3. $40.
2007 Honda 919 CB900F Parts, 2007 Honda 919 CB900F OEM Parts - BikeBandit.com
post #18 of 26 Old 04-24-2013, 04:23 PM
Are splines on the part still good?
If so just pick up an easy out and drill the busted bolt on center and draw the busted shank out. You will need a vice to hold it securely, and a drill bit that matches the easy out specs.
post #19 of 26 Old 04-24-2013, 05:02 PM Thread Starter
Man and Machine
I hacked it off..yep, when I f things up I really f things up.
post #20 of 26 Old 04-24-2013, 05:12 PM
Hmmm ..... well scratch my idea.
I second G00gl3it's call on ordering the OEM setup.
post #21 of 26 Old 04-24-2013, 05:52 PM
Damn, you could of just sawed through the bolt itself and used a screwdriver to pry the bracket open enough to pull it off?
post #22 of 26 Old 04-24-2013, 06:23 PM
Tough to fit a hacksaw at that location. But a dremel would fit right in there. Too late now...
post #23 of 26 Old 04-24-2013, 06:39 PM Thread Starter
Man and Machine
Moderator can close this thread. Thanks guys for the input. Will be ordering new linkage parts.
post #24 of 26 Old 04-24-2013, 07:16 PM
Good point. This'll be a great thread for future reference.
OP, good luck finding a new bracket. Let us know if you're able to pick one up for a decent price.
post #25 of 26 Old 04-24-2013, 08:26 PM
I've tried this on another dirt bike with a similar problem on a broken off kick-starter.
By the time you've pried it apart far enough to clear the bolt from the recessed groove on the shaft, you'll either A) snap the outer piece in half or B) really screw up the splines trying to slide the sucker off.
Didn't even think about the dremel, though, lol. Wouldn't do Helimech any good, it's too 'artsy n craftsy'.
post #26 of 26 Old 04-24-2013, 09:48 PM
Damn that sucks, but good to know.
