My winter projects so far - Wrist Twisters
post #1 of 10 Old 01-25-2009, 07:28 AM Thread Starter
have consisted of:
New fuel filter, air filter and antifreeze for the Hurricane.
New air filter, plugs, and valve check on the 919.
New plugs, air filter, valve check, carb sync and cam chain tensioners for the Hawk.
I rebuilt the F3 last year so it's all good.
The most difficult one of the bunch is the Hawk. There's a lot of fairings to come off the Hurricane, but it's easy stuff and pulling the tank is a breeze. The 919 is naked and exposed, so not too bad except extremely tight valve cover clearance. The Hawk is not bad, just time consuming, cramped and steals your patience away.
The rear tensioner was on it's way out, and the cam timing was one tooth off on the intake. I guess I caught it just in time. Everything went back together well and it sounds good.
None of the valves on the 9 or the Hawk were out. Good thing, I hate pulling cams.
Now I wait for warmer weather.
post #2 of 10 Old 01-25-2009, 07:34 AM
Jim: Glad to hear you are taking good care of my Hurricane!
post #3 of 10 Old 01-25-2009, 07:38 AM
Trying to get me motivated to get off my butt or what?
Superduke
R1200GS
XR650L
post #4 of 10 Old 01-25-2009, 08:36 AM Thread Starter
Set fire to your chair. You'll motivate real fast.
It's almost impossible to get the 9 head cover back on with the gasket in place. Took me awhile.
post #5 of 10 Old 01-25-2009, 08:50 AM
Sadly I've done more work to my garage then my bike. I just built some shelves, then cleaned and put everything up. Its much nicer to work out there now though, much more organized. I've got just enough lumber left to frame out a nice cabinet, big enough for my Helmets, Gear, and to hang my jackets in. Might do that today.
Other than that I mounted a flyscreen on my FXR and washed my snowmobiles to sell them.
post #6 of 10 Old 01-25-2009, 10:49 AM
I noticed you replaced air filter on the 9'er. The service manual never really tells you to replace, just clean with compressed air. Is there a general rule of thumb that they should be replaced after a certain number of miles or just when they look like crap?
marylandmike is online now
post #7 of 10 Old 01-25-2009, 11:04 AM
Stare into me...
GDJAM's Avatar
Did you ever post up final pics on the F3? If so, I missed them.
GDJAM is offline
post #8 of 10 Old 01-26-2009, 02:54 AM Thread Starter
Check here for the pics:
https://www.wristtwisters.com/forum/s...hanical+mayhem
Mike, the Honda service manual says to clean it every 12,000 miles. The bike is approaching 30,000 and blowing the filter out was leaving a lot of dirt so I replaced it. I guess I could run it through the dishwasher.
post #9 of 10 Old 01-26-2009, 04:19 AM
Makes sense. Thanks Jim
post #10 of 10 Old 01-26-2009, 04:24 AM
MuscleCar Nut
67GTONUT's Avatar
Garage is just too cold.....
GTO has a To-Do list..... it will wait until March...
Troy
67 Pontiac GTO
2003 Triumph Speedmaster
67GTONUT is offline
