Motovation 919 frame sliders discontinued - any other thru-frame options? - Wrist Twisters
post #1 of 6 Old 07-14-2014, 10:55 AM Thread Starter
I need to replace my Motovation frame sliders on my 919 (long story - don't ask...). I just called Motovation and they discontinued them for the 919 about a month ago - which seems odd because he said they get 1-2 calls per week for them...
Are there any other options for frame sliders that go through the frame, instead of bolting to the engine?
Thanks!
post #2 of 6 Old 07-14-2014, 11:04 AM
Philanthropist
Dave W.'s Avatar
Not sure, but my 919 maybe on the chopping block in exchange for a bmw S1000r. If so, I'll pull my sliders for you before I trade it in.
Or you could buy my vfr800 which is currently listed in the classifieds....
Dave W. is offline
post #3 of 6 Old 07-14-2014, 11:38 AM
Tool & Die
morrow919's Avatar
T-Rex sliders are really good. I've used mine in a slide and a tip over and they've worked perfectly. You could buy the T-Rex sliders and just use the rod from your motovation sliders. I bought T-Rex and cut a rod to length and threaded both ends.
'07 Hornet - Candy Glory Red
morrow919 is offline
post #4 of 6 Old 07-14-2014, 12:09 PM Thread Starter
Keep me posted - if you get rid of it I'll be interested in buying your sliders.
The VFR would be a nice, but pricey, alternative to new sliders!
The T-Rex pucks are definitely priced right. What did you use for the rod? One side of mine is bent, so I'll either need to get a full slider set, or do the same thing you did.
post #5 of 6 Old 08-06-2014, 05:02 PM
redline919's Avatar
Check again. Limited batch being produced. Accepting preorders for the Motovation sliders
redline919 is offline
post #6 of 6 Old 08-07-2014, 10:18 AM Thread Starter
Thanks! I just called them - they plan to do a run of about 20 kits for the 919, sometime in the next few weeks.
I only need the bolt and the right side slider puck - it turns out the only replacement parts they have left is 1 bolt and a couple right side slider pucks. I just ordered the parts! Thanks again!
