More Flexible Cutting Board Uses - Wrist Twisters
post #1 of 18 Old 05-25-2015, 06:00 AM Thread Starter
"CERTIFIABLE"
Ken Phenix's Avatar
I have used this stuff to make rim protectors when changing tires
and to keep oil off the header when changing the oil and filter.
I changed my rear tire yesterday and thought of yet another use. When installing the wheel I put the pieces I had used as rim protectors between the axle spacers and the swingarm to keep the spacers from getting cockeyed or falling out and to keep the left spacer from hanging up on the axle adjuster clevis. I pulled them out one at a time as I ran the axle through. Works like a charm.
Ken Phenix is offline
post #2 of 18 Old 05-25-2015, 06:35 AM
Great ideas Ken. I changed my front tire on Saturday. I used cut up yogurt containers, but these should be even better because they are thinner. Gonna try these when I change the rear tire.
post #3 of 18 Old 05-25-2015, 06:35 AM
redline919's Avatar
Damn that's some dirty oil!
redline919 is offline
post #4 of 18 Old 05-28-2015, 02:48 AM
Course it's dirty!
Ken goes to the corner store for milk in the evening, then figures, WTF, he'll press on and do 1,000 extra miles while everyone else is sleeping, just for the hell of it.
K1w1Boy is offline
post #5 of 18 Old 05-28-2015, 07:32 AM
StormSurfer
Whiplash97's Avatar
Originally Posted by K1w1Boy View Post
Course it's dirty! Ken goes to the corner store for milk in the evening, then figures, WTF, he'll press on and do 1,000 extra miles while everyone else is sleeping, just for the hell of it.
Lol! No shit right!?
:buell:
Whiplash97 is offline
post #6 of 18 Old 05-28-2015, 08:49 AM
Good idea for the oil change!!! i will be stealing one of my wifes cutting boards next oil change..
post #7 of 18 Old 05-28-2015, 01:26 PM
NWTB Non Stinky 919
jeffie7's Avatar
I use foil for the header but that looks to work better. How does the food taste when you use them for cutting up stuff?
jeffie7 is offline
post #8 of 18 Old 05-28-2015, 02:37 PM
Best tool I have found to protect the headers during an oil change. Tight spot funnel (few bucks in the auto section at Wally World). It's kind of rubbery and fits between the headers. Use it to fill new oil too.
post #9 of 18 Old 05-30-2015, 12:57 PM Thread Starter
"CERTIFIABLE"
Ken Phenix's Avatar
They never have it in stock whenever I go. But of course you know I can't go to Wally world unless I'm wearing my "Tank, I need an exit!" t-shirt.
post #10 of 18 Old 05-30-2015, 01:02 PM Thread Starter
"CERTIFIABLE"
Ken Phenix's Avatar
Course it's dirty!
Yep. The IBA and Blackstone Labs say it's alright to change your oil every 10,000 miles if you do them all at once.
post #11 of 18 Old 05-30-2015, 01:52 PM
redline919's Avatar
Haha , I see your point. Quick question. What seat or seat pad are you using to rack up all of those miles? That is my only complaint with long distances on the 9er. I have a Sargent seat which doesn't do much. If I ride for a couple hours I'm hurting pretty bad
post #12 of 18 Old 05-30-2015, 01:54 PM
I always used foil, but the funnel idea looks a lot better. Plus, I shouldn't run out of kitchen foil now. I was thinking about picking up one of the $70 bead breaker kits on Amazon too. Definitely going to pick up those cutting boards to protect the rims.
post #13 of 18 Old 05-30-2015, 07:49 PM Thread Starter
"CERTIFIABLE"
Ken Phenix's Avatar
AirHawk baby! I wouldn't leave home without it. The only issue is the straps are designed to loop under the seat which means you have to pull the seat every time you put it on. The hooks are kinda cheesy so they have been known to fly off when an unsuspecting rider stands up on the pegs. I added straps with little tiny S-Biners to attachment points on the bottom of the air box and on my side case racks. Now it's totally secure and I can remove it easily if I'm going to be away from the bike a while.
I'm sure this will get me a big fat TWSS but my butt does not get sore.
post #14 of 18 Old 05-30-2015, 08:43 PM
redline919's Avatar
Right on. I'm gonna have to invest in one for sure. Thanks for the tip. Good to hear this positive feedback from someone who actually rides there bike
post #15 of 18 Old 05-30-2015, 09:59 PM
StormSurfer
Whiplash97's Avatar
I have used this stuff to make rim protectors when changing tires and to keep oil off the header when changing the oil and filter. I changed my rear tire yesterday and thought of yet another use. When installing the wheel I put the pieces I had used as rim protectors between the axle spacers and the swingarm to keep the spacers from getting cockeyed or falling out and to keep the left spacer from hanging up on the axle adjuster clevis. I pulled them out one at a time as I ran the axle through. Works like a charm.
So what oil drains the best when using these? Or what would be the best oil to use to get it to drain properly?
:buell:
post #16 of 18 Old 05-31-2015, 08:52 AM Thread Starter
"CERTIFIABLE"
Ken Phenix's Avatar
Just spray the plastic with this and the motor oil won't stick.
post #17 of 18 Old 05-31-2015, 03:11 PM
StormSurfer
Whiplash97's Avatar
Ha! Right on ken!
:buell:
post #18 of 18 Old 05-31-2015, 04:56 PM
NWTB Non Stinky 919
jeffie7's Avatar
Why wouldn't you use wd40? Plus when done, just wipe it off with a rag and wipe the rag onto your chain.
2 birds 1 stone.
jeffie7 is offline
