Mix 'n Match calipers and master cylinders - Wrist Twisters
post #1 of 6 Old 04-01-2016, 01:45 PM Thread Starter
What do I need to know when mixing and matching master cylinders to my brake calipers?
I've got non-radial brakes on a set of GSXR 750 forks. The matching master cylinder here is questionable... I've heard that an R1 master cylinder bolts right up, but what do I need to know to determine what will fit for myself?
post #2 of 6 Old 04-01-2016, 03:26 PM
Which calipers do you have?
K1w1Boy is offline
post #3 of 6 Old 04-01-2016, 03:33 PM
I was doing this last year, ended up with a set-up I'm really happy with, all the way down to the [gasp] disk rotors from China.
Might be something here to help you out
https://www.wristtwisters.com/forums/...wap-60993.html
K1w1Boy is offline
post #4 of 6 Old 04-01-2016, 03:41 PM Thread Starter
From what I can tell, I have bone stock components.
post #5 of 6 Old 04-01-2016, 04:00 PM
I ended up with these calipers
1999-Present CBR600F4(i) mc 5/8” (15.87mm)
caliper pistons 34mm/32mm
and this m/cylinder
GSXR600/750 '04-'07 - OEM Radial Master Cylinder, 19.05mm
and find the whole set-up a huge improvement over how my stock set-up worked. Some folks report good feel and good stopping power from bone stock, but mine was lousy.
K1w1Boy is offline
post #6 of 6 Old 04-01-2016, 05:39 PM
This can be of help: https://www.wristtwisters.com/forums/...der-48345.html
All it requires is the caliper piston diameters and as precise as possible measurements from whatever master cylinder (M/C) you want, or guidance on how to select one with the right bore and mechanical leverage ratios. Of course it can also be used to select a suitable axial M/C.
I used this procedure to determine that a M/C from a CBR1000 would be a suitable replacement for the stock 919 M/C, taking into account the feel I was shooting for.
