Misfire when wet - Wrist Twisters
post #1 of 9 Old 03-10-2015, 11:12 AM Thread Starter
Misfire when wet
Recently I've had an issue with the 04 919 with a misfire on cylinder 1 when riding in the rain or even on wet roads. I've pulled that plug and it looks just fine. However, in my completely scientific testing, I've noticed when I let the bike idle in the garage and throw water on top of the engine, one of the wires (I'm assuming to cylinder 1) was arcing visibly in the middle under the frame. Trying to reproduce it later didn't visibly show the spark, but it still produced the misfire and made the clicking sound indicating a voltage leak. Moving the wires didn't seem to effect the issue.
As far as I can tell, water isn't getting into the actual plug holes at all and the boots look ok. Has anyone else had this issue? I didn't think it would be a problem on a bike with only 7400 miles and an untouched ignition system.
zgrounds is offline
post #2 of 9 Old 03-10-2015, 11:26 AM
unscientific or not, anytime you can see visible arcing there's something seriously wrong going on... First I'd check and make sure all your ground wires are tight, and then replace the plug wires... Small cuts in the insulation can be hard to spot but cause big problems...
post #3 of 9 Old 03-10-2015, 12:20 PM
carotman's Avatar
The wire could arc in a place and not in the other.
Replace the plug wire, they do go bad.
carotman is offline
post #4 of 9 Old 03-10-2015, 01:59 PM Thread Starter
Well I think I found the problem... Insulation is ripped through all the way to the wire. Anyone know how to get the wire out of the boot? They are sold as two pieces.[IMG][/IMG]
zgrounds is offline
post #5 of 9 Old 03-10-2015, 02:03 PM
post #6 of 9 Old 03-10-2015, 02:55 PM Thread Starter
Fixed with a gratuitous amount of electrical tape for now. Seems to have fixed the problem at least until the new wires ship. Thanks guys.
zgrounds is offline
post #7 of 9 Old 03-10-2015, 07:43 PM
carotman's Avatar
The wire is just screwed on the boot.
carotman is offline
post #8 of 9 Old 05-16-2015, 09:18 PM
captainchadl's Avatar
Should the boots be replaced too? Can the boots leak? At least one wire on my bike is leaking and it is black in those spots, but no sign of breaks. Can the isulation just get old and not resist as much?
captainchadl is offline
post #9 of 9 Old 05-16-2015, 11:43 PM
Yes and yes.
Just FYI, the wires and boots are sold separately.
Boots:
30700-MCZ-000, MSRP $21.04, need four.
Wires:
WIRE, IGNITION (1) 30733-MCE-505 $13.65 (Old number 30731-MCZ-003)
WIRE, IGNITION (2) 30732-MCZ-003 $12.93
WIRE, IGNITION (3) 30733-MCZ-003 $13.51
WIRE, IGNITION (4) 30734-MCZ-505 $9.00 (Old number 30734-MCZ-003)
