mirrors w/ turn signals blinking too fast - Wrist Twisters
post #1 of 11 Old 07-17-2011, 05:15 PM Thread Starter
benr's Avatar
I have a set of mirrors with intergrated LED signals on them (cheapys). I need to slow them down, as they blink very fast. I remember doing this before for my old cbr for the rear tail. I used resistors, but can not remmeber what type and where to get them.
Any sugestions? I want to get it locally so I am not waiting on parts, automotive stores etc
benr is offline
post #2 of 11 Old 07-17-2011, 06:01 PM
Solid state flasher will fix your issue.
post #3 of 11 Old 07-17-2011, 07:11 PM
custom led flasher relay. plug and play
post #4 of 11 Old 07-17-2011, 08:09 PM
Be a rebel, do it the hard way and install a resistor in-line.
post #5 of 11 Old 07-17-2011, 08:38 PM
... and watch your bike go on fire. :P
CB700S is online now
post #6 of 11 Old 07-17-2011, 09:18 PM Thread Starter
benr's Avatar
lol i thought i used resistors before, but could be wrong. They get hot yes, but do they produce enough heat for any damage to happen?
benr is offline
post #7 of 11 Old 07-17-2011, 10:11 PM
they could, depending on mounting location, etc... I originally was going to toss resistors into the frame of the bike in the rear, but when I discovered this mess I also discovered a flasher so was able to avoid that route. I spent a couple of hours with an iron and shrink wrap "fixing" that max.
post #8 of 11 Old 07-18-2011, 06:34 AM Thread Starter
benr's Avatar
Is this it? and a fair price?
Custom LED Universal Flasher Relay for Aftermarket LEDs /Signals [ELFR-1] : Bayside Performance, Canadian Source for 98-2010 Motorcycle Parts, Sportbike Accessories And Apparel
Also I will be changing the rear to smaller, and possibley LED units. Bayside notes the following:
NOTE: In some rare instances, when there are NO incandescent loads on the blinker system (LEDs front and rear), one pair of our Stage I Load Equalizers will also be required to prevent a wide range of blinker problems. These problems are all associated with a lack of resistive load on an all-LED blinker system that was designed for incandescent lamps. Problems such as, but not limited to: the 4-way blink problem (both sides blinking at the same time), the no-blink problem, and Integrated LED Tail Lights staying in "blinker mode" due to non-zero blinker voltages.
Anyone have this setup?
benr is offline
post #9 of 11 Old 07-18-2011, 09:21 AM
^^ That's the one. Check CLED's site too.
post #10 of 11 Old 07-18-2011, 01:23 PM
yup. Its the ELFR-1
buy it directly from custom led. your better off and they take paypal. always quick shipping
Custom LED Electronic LED Flasher Blinker Relay - Plug And Play
post #11 of 11 Old 07-18-2011, 01:25 PM
+1^^^^^ Just put it in two weeks ago and unsoldered the resistors from my Rizoma LED's to save space in the headlight bucket for the Koso gauge. No issues so far.
I should have done this from day UNO. Would have saved me a ton of time.
