Little Help ??? Valve Ticking Sound ??? - Wrist Twisters
 1Likes
  • 1 Post By Sniper-x
post #1 of 6 Old 08-18-2018, 01:56 PM Thread Starter
Got a 07 with only 4700 miles. Have something I believe on the left side front of the engine making what sounds like a valve ticking. It's louder when the bike is cold. The strange thing, seems to only make it when the bike is moving. I can't hear it when I rev it cold or hot. Any ideas? I owned a few VFR's, this is my first 919... Save the "left handed monkey wrench" comments for the kids... Thanks
jbird is offline
post #2 of 6 Old 08-18-2018, 02:09 PM Thread Starter
Got my own answer.. Piston slap.. Huh.. Okay..
jbird is offline
post #3 of 6 Old 08-18-2018, 08:46 PM
4700 miles, that thing isn't good and broken in yet.
You're probably hearing the fuel injectors. Nothing to worry about.
mcromo44 likes this.
Sniper-x is offline
post #4 of 6 Old 08-19-2018, 01:38 PM
nathanktm's Avatar
I believe it is the fuel injectors. I hear the exact same thing, used to drive me insane. It's not too bad initially on start up, worst about a minute in, and slowly gets better as the bike heats up. If you drag the clutch hard with the brakes held at a stop, it gets very loud. I'm pretty sure everyone has that sound, and nobody has had a problem.
nathanktm is offline
post #5 of 6 Old 08-19-2018, 03:32 PM
I get a little valve train noise if I load the engine up. If I'm in too high a gear, low revs and I pin the throttle there is some valve train rattle.
post #6 of 6 Old 08-19-2018, 05:51 PM
Audible piston slap from a low mileage, tight cylinder wall clearance engine with rather dimensionally stable cast super pistons, that's water cooled sounds is a rather iffy proposition in my mind.
Injector noise is much more likely, like others above have already suggested.
