Lighting upgrade idea. LED side lights using headlight type LEDs. - Wrist Twisters
 4Likes
  • 1 Post By marylandmike
  • 2 Post By Islandboy
  • 1 Post By Islandboy
post #1 of 16 Old 03-12-2019, 10:50 PM Thread Starter
It looks like headlight (H4) LED bulbs are getting real cheap now. I wonder if having 3 headlight would be a good idea. 1 as the primary and 2 others on the side but instead of regular weak bulbs, use headlight LED.
This could really light things up.
The problem is we have to see the condition of the road right in front of us AND we need to see what's going on way ahead.
I have some old side lights, but they aren't LED. I'd like to have something that lights up the sides, middle and far center.
post #2 of 16 Old 03-13-2019, 05:19 PM
Do you have an LED headlight now? I put in a GE Nighthawk LED a few years ago and it really lights things up. I am thinking two more would be overkill.
Pics below are from a road with no streetlights.
For reference all lights off:
Low beam
High Beam
post #3 of 16 Old 03-13-2019, 06:39 PM
Low beam
High Beam
Wow!
That's impressive.
Now that you've had it a few years, how do you find the relationship between the hi and low patterns are, once you've set the light up for best low beam positioning?
Is the hi too high, or too low, or just right?
Did you do any posts back then re your install?
I'm assuming some level of adaptation was needed.
post #4 of 16 Old 03-13-2019, 07:45 PM
Wow!
That's impressive.
There is a plate inside of the light that provides a pretty sharp cutoff for the low beam, so it doesn't blind drivers once you get it set. I haven't had to do any adjustments since I have had it. I don't really ride a tremendous amount at night though. The reason I got it was a few of us had done a trip to the tail of the dragon and it was downright scary riding on curvy roads at night with the stock headlight.
Below is a thread showing the install process. Definitely not just a drop in.
https://www.wristtwisters.com/forums...iew-51842.html
mcromo44 likes this.
post #5 of 16 Old 03-13-2019, 10:50 PM
Thanks for pulling it up for all!
post #6 of 16 Old 03-13-2019, 11:25 PM Thread Starter
Wow on both the performance and the price:
https://www.amazon.com/GE-Lighting-6.../dp/B00BQX2BT8
$294 vs $50~100 for others.
post #7 of 16 Old 03-14-2019, 08:42 AM
Agree on the current price. At the time I got mine they had a $100 off coupon so I paid $152. I think that the GE one is pretty close to the Trucklite which you can find on Amazon for about $150. Several folks have installed those. Carotman has a great thread on that somewhere.
post #8 of 16 Old 03-14-2019, 11:44 AM
Mike I believe there is another way to mount your light unit into the stock headlight bucket.
I noticed in your install write up pics that the reverse of your light unit has three small locator keys on the back around the edge. So does the headlight rim assembly of a cb400. The rim assembly sandwiches the light unit and allows you to mount it in the stock bucket. The holes in the bucket are slightly off so a little fibreglass and re drilling is required. But it makes for a very solid mount. This rim assembly also has a screw for left and right beam direction adjustment. I used a different led light unit but it had identical locator tabs/keys on the back. I'd bet my left nut it would work for your light unit also.
marylandmike and mcromo44 like this.
post #9 of 16 Old 03-14-2019, 11:47 AM
Same as Carotman.
post #10 of 16 Old 03-14-2019, 06:30 PM
What vintage of CB400?
post #11 of 16 Old 03-14-2019, 07:11 PM
I got it wrong. It's a headlight rim assembly for a CB450, Cb500 and a few others. Mid 70s?
Here is a link to the exact one I brought.
https://4into1.com/7-chrome-headligh...0-gl1000-1200/
The pic I've posted shows the reverse of my style Led headlight. I've marked the location of the lugs. I'm sure they are the same as the ones on Mike's headlight. Probably other 7" headlights like it to.
post #12 of 16 Old 03-14-2019, 08:04 PM
Excellent information. Thank you!
post #13 of 16 Old 03-14-2019, 08:35 PM
Those rings go back to at least 1969 in origin.
The tabs on the lights themselves are automotive standard, probably covered by an SAE spec, as is the light dispersal.
So, you got the ring to nicely mate up to the 919 bucket.
Without looking, I think the 919 bucket has more effective volume than the ancient CB-K ones, otherwise I was thinking of trying one of those.
Ultimately, an early ring looks like the ticket.
post #14 of 16 Old 03-14-2019, 09:07 PM
I actually thought those rings and lug system was possibly automotive in origin. You often see those headlight units advertised for Jeeps. I think Mr Honda in the early days had a knack for recycling.
I also thought about using an early bucket but decided against it because they looked less than the 919 in volume. All that wiring has got to go somewhere. The actual holes for the rim and bucket to bolt together are not that far off. You could probably get away with making them wider. I felt is best to fibreglass over the old holes and redrill new mount holes.
post #15 of 16 Old 03-19-2019, 11:07 AM
PB
DSB_ESQ's Avatar
I bought an Eagle Lights 7" light:
https://www.eaglelights.com/collecti...led-headlights
On the back there are two through holes that run from right to left, one on top and one on the bottom. I 3D printed a bracket that interfaces with those holes and the mounting slots on the existing headlight ring. All you need to do is bolt the bracket to the headlight and then secure the bracket and headlight to the ring. I've got the file for the bracket if anyone else wants to 3D print the adapters.
DSB_ESQ is offline
post #16 of 16 Old 03-24-2019, 02:12 PM
That would be nice, how can i contact you for a file request?
Отправлено с моего SM-P605 через Tapatalk
Gattsthebranded is offline
