License Plate Light - Wrist Twisters
 1Likes
  • 1 Post By SPYDER
post #1 of 16 Old 07-19-2017, 05:09 PM Thread Starter
TheScientist's Avatar
License Plate Light
Alright, who hid my license plate light? I don't seem to have one. The plate is not lit up. The only thing I can think of is light should be coming from the rear running lights but there isn't a place for light to rear the plate. Maybe the guy before me painted the rear light shroud black?? IDK. So simple of a question but I can't find the answer anywhere. I'm going for my motorcycle skills test next week so I need to get the plate lit by then.
2003 Honda CB900 919 Hornet - Current
1999 Suzuki Bandit S1200 - sold
1986 Honda Magna V65 - sold
TheScientist is offline
post #2 of 16 Old 07-19-2017, 08:21 PM
Don't know if this helps. My stock rear fender, off bike. Pic shows plate light.
post #3 of 16 Old 07-20-2017, 05:12 AM
If you don't have the OEM rear fender you can get a plate frame that has LEDs built in.
I've been running one of these for years with no issues...
https://www.customdynamics.com/horiz...d-illumination
garyb900 is offline
post #4 of 16 Old 07-20-2017, 03:06 PM Thread Starter
I thought I replied earlier... I guess I don't have an own fender. Problem is, the cans installed are closer together than stock so I had to cut my plate down on both sides by 1/4". That means I can't use any plate frame. I'll need to find some plain lights it seems. Anyone have aftermarket license plate lights other than on a plate frame?
post #5 of 16 Old 07-20-2017, 03:21 PM
When I made my rear fender I brought from ebay two Led plate lights. These I fitted to fender and wired up to stock plate light wires. They are a bit hard to see in pic cause they are black. Cost about 5 bucks. Oh yeah, made in china.
File Type: jpg 20170326_161427-1-1-1_1500589060138.jpg (156.9 KB, 12 views)
post #6 of 16 Old 07-20-2017, 03:37 PM
LED bolt lights,
https://www.customdynamics.com/led-t...white-tag-leds
https://www.customdynamics.com/categ...unts/tag-boltz
garyb900 is offline
post #7 of 16 Old 07-20-2017, 04:32 PM
RIDE RED
SPYDER's Avatar
https://www.ebay.com/itm/182040095844
These are what I had on my old 919 cheap and bright
SPYDER is offline
post #8 of 16 Old 07-20-2017, 05:11 PM
bartsitarski's Avatar
I have these and the work great. I use them instead of the top plate bolts.
https://www.amazon.com/gp/aw/d/B008R...2PC0H1DW6KQ1XC
-Michael Jordan
bartsitarski is offline
post #9 of 16 Old 07-20-2017, 06:45 PM Thread Starter
Thanks guys I had no idea these bolt lights existed. That's exactly what I'll do.
Looking at that bike pic, it gives me the warm fuzzies. Those alien like tank and fairing angles and lines... beautiful.
post #10 of 16 Old 07-21-2017, 10:55 AM
These are pretty much the exact light bolts I used. SPYDER's right. Cheap and bright. You could probably use two as the top two plate anchor bolts. Or do what I did and mount them above the plate, facing down.
post #11 of 16 Old 07-21-2017, 05:04 PM Thread Starter
I took a closer look at it today. It's all completely different with a custom plate bracket. I forgot I had to drill the holes through the state name so their bolt location won't work but I think I can use the bolt holes which hold the bracket on.
post #12 of 16 Old 07-21-2017, 05:06 PM Thread Starter
The bandit had nothing to do with anything I just wanted to see how posting pictures worked on here. That was my last bike. 99 Suzuki bandit S1200. Very very clean and ran spectacularly.
post #13 of 16 Old 07-23-2017, 08:36 AM Thread Starter
Going to tap into the running lights for the license plate lights. I don't like working on electrical often so I wanted to run this past you.
My plan is to either use a quick clamp type connector like with low voltage lights or cut and solder with shrink tubing (I'm very good at this) which would take a bit longer. I THINK I should tap into the brow wire with the red wire of the plate light and one of the green for the neutral. Is this correct? If so, does it matter which green?
post #14 of 16 Old 07-23-2017, 08:50 AM Thread Starter
I suppose I should ask where the original plate lights are wired? I should tap into that instead of the running lights.
post #15 of 16 Old 07-23-2017, 11:13 AM
RIDE RED
SPYDER's Avatar
There should be a two wire plug hanging out at the rear of your frame that used to be for the stock light
TheScientist likes this.
SPYDER is offline
post #16 of 16 Old 07-23-2017, 02:42 PM Thread Starter
Thanks! Found it deep inside the rubber boot. All is working now. Also installed some led tail lights. Omg they're bright!
