Kickstand safety switch - Wrist Twisters
post #1 of 33 Old 03-31-2015, 03:03 PM Thread Starter
RIDE RED
SPYDER's Avatar
As anyone had this fail at highway speed? My bike just died and then wouldn't start fuel pump would run but not start. After pushing it to the nearest house and calling a friend with a truck she fired right up!?!? I'm assuming now that putting the stand up and down made it fix itself. I'm going to use some contact cleaner on it. If that doesn't work is that switch normally open or normally closed? so I know how to bypass it. Thank in advance my first thought was something came apart internally not that I don't trust my mechanic skills but I didn't get to ride too much after having her apart last year.
SPYDER is offline
post #2 of 33 Old 03-31-2015, 04:02 PM
Dragon Slayer
oak1971's Avatar
It probably creates an open when in the down position. Just cut the wires and twist them together you'll know right away if it works. Or better yet, just put a jumper wire in the plug end for a temporary test.
2002 SuperHornet 919 - In a continuously variable state of modification.
1974 CB360- awaiting restoration money
Past Bikes:
1981 XL 80
1984? Nighthawk 650
1992? Zephyr 1100
1991? ZX-11
1999 ZRX 1100
1984 V45 Magna
2001 GSXR 750
1985 Shadow 1100
oak1971 is offline
post #3 of 33 Old 03-31-2015, 04:11 PM Thread Starter
RIDE RED
SPYDER's Avatar
Thanks from the looks of where the wires go I've gotta take half the bike apart to get to the plug lol think I'm going to try to get to the plug and in plug it if it starts cool if not jump it
But now she fires right off every time wondering if I've got a coil getting hot and killing spark? Oh the possibilities I don't want to spend another summer looking at her in the garage
SPYDER is offline
post #4 of 33 Old 03-31-2015, 04:17 PM Thread Starter
RIDE RED
SPYDER's Avatar
Ok wasn't too bad....
Side cover and air box lid unplug and she runs so now the switch is out of the equation we'll see what tomorrow brings
SPYDER is offline
post #5 of 33 Old 03-31-2015, 04:43 PM Thread Starter
RIDE RED
SPYDER's Avatar
Ok so I was wrong it'll start but as soon as I it it on gear it dies so the switch completes the circuit Stand up doesn't ground out the ignition stand down
Too me that's stupid but I'm no engineer lol
SPYDER is offline
post #6 of 33 Old 03-31-2015, 05:02 PM Thread Starter
RIDE RED
SPYDER's Avatar
So I'm thinking it's not the kick stand switch just went out tooling around town trying to see if she would die on me came home put her on the center stand let idle in garage as the temp came up she shut off and now won't start just like before?
SPYDER is offline
post #7 of 33 Old 03-31-2015, 05:05 PM Thread Starter
RIDE RED
SPYDER's Avatar
And not warm enough for the cooling fan to kick on?
SPYDER is offline
post #8 of 33 Old 03-31-2015, 05:44 PM Thread Starter
RIDE RED
SPYDER's Avatar
I know it's a PITA but would someone be willing to post pick of their coil wiring I just want to make sure I put them back in the correct place I'm not talking coil wires but the small gauge wires
SPYDER is offline
post #9 of 33 Old 04-01-2015, 07:06 AM Thread Starter
RIDE RED
SPYDER's Avatar
The more I run through in my head how the bike acted right before shut down I'm thinking I've definitely got a bad coil. As I accelerated it sounded like it hit the rev limiter so I'm going to lift the tank start her up wait for her to die then check for spark. Since the probes on my multi meter won't reach into the plug wire ports on the coils
SPYDER is offline
post #10 of 33 Old 04-01-2015, 02:48 PM Thread Starter
RIDE RED
SPYDER's Avatar
Ok so what are the odds both coils are bad at the same time? Now I'm thinking it may be something else. She fired right up after sitting over night ran for 15-20 min on center stand then died I pulled #4 first put a plug in the boot zero spark same with #1&2 didn't pull #3 for obvious reasons . Anyone got anything? I didn't get to ride much last year because of the broken valve spring and waiting on parts I'd really like to put some miles on this year!
SPYDER is offline
post #11 of 33 Old 04-01-2015, 03:10 PM Thread Starter
RIDE RED
SPYDER's Avatar
Now I see the FI light comes on steady after she dies and I try to restart how do I pull codes from this thing?
SPYDER is offline
post #12 of 33 Old 04-01-2015, 03:19 PM
There is a open small two wire plug in the tail section. Jumper the terminals with a piece of wire .... then turn on the ignition & the light will flash a code.
post #13 of 33 Old 04-01-2015, 03:20 PM Thread Starter
RIDE RED
SPYDER's Avatar
thanks Heli that's what I thought but didn't want to fry something
SPYDER is offline
post #14 of 33 Old 04-01-2015, 03:25 PM
No worries man .... I'll get you some coil wiring info tonight as well. I also have a two extra set of 919 coils in the parts bin if you need some.
post #15 of 33 Old 04-01-2015, 03:33 PM Thread Starter
RIDE RED
SPYDER's Avatar
If this works like s car I got 17,89,12,13,14,15,18,19 that's a whole lot of numbers but after pulling codes I took the jumper out and she fired right up again I'm gonna go look at the digital manual I got off here and see if I can find out what these mean
SPYDER is offline
post #16 of 33 Old 04-01-2015, 03:39 PM
Its the same as a old school OBD-0 car. Long dash - first number .... short dash - second number. That's a lot of codes!
post #17 of 33 Old 04-01-2015, 03:43 PM Thread Starter
RIDE RED
SPYDER's Avatar
No shit still trying to find what they all mean she seamed to be running fine it's weird that after a bit she'll start and run then just die
SPYDER is offline
post #18 of 33 Old 04-01-2015, 03:43 PM
Coil info .....
Aft side frame mounted coil feeds cylinder #2 & #3.
Fwd under frame mounted coil feeds cylinder #1 & #4.
The small gauge trigger wires are the same on both. Black wire goes to spade terminal with black base. Colored wire goes to spade terminal with green base.
post #19 of 33 Old 04-01-2015, 03:48 PM
I just got my 919 out of storage and back in the garage tonight. I'll be in the shop going through it tonight .... and I'll have my FSM handy if you need any other info.
BTW I spliced my coil harness last winter so pay no mind to the colored heat shrink.
And I just noticed a chaffed cable .... hmmmm shitty.
post #20 of 33 Old 04-01-2015, 03:50 PM Thread Starter
RIDE RED
SPYDER's Avatar
That's how I've got them thanks still scrolling to find code meanings wife says Tom for supper lol
SPYDER is offline
post #21 of 33 Old 04-01-2015, 03:52 PM
Haha .... i have a paper copy of the FSM. Go eat I'll get you the codes for you.
post #22 of 33 Old 04-01-2015, 04:04 PM Thread Starter
RIDE RED
SPYDER's Avatar
Hey thanks a million man she gets kinda testy when I spend too much time with the girlfriend lol
SPYDER is offline
post #23 of 33 Old 04-01-2015, 04:08 PM
So the ECU only supports twenty codes in total ... numbered #1 through #20 found on pages 5-10 & 5-11.
I would try to read them again and let it run through the flashes for a bit. Eventually you will start to see a pattern .... then start your count and see what codes you come up with.
Long 1.3 second dash = first number
Short 0.5 second dashes = second number
post #24 of 33 Old 04-01-2015, 04:18 PM Thread Starter
RIDE RED
SPYDER's Avatar
Ok so maybe it's 1,7,8,9,12,13,14,15,18,19 I think all that shares a plug which I had disconnected last fall ill check the connection and get back to you thanks man hope it's just the connection
SPYDER is offline
post #25 of 33 Old 04-01-2015, 04:22 PM
Do you have a PC3 installed?
If so check for loose connections or cracked wires ... I have seen the power/ground & TPS wires crack near the base where they branch of the main bundle.
post #26 of 33 Old 04-01-2015, 04:30 PM Thread Starter
RIDE RED
SPYDER's Avatar
No programmer the injectors all share a plug but everything else is separate but it was all unhooked when I pulled the top end off last summer/fall think I'm going to disconnect the battery to try to clear the computer all connections seam clean and free of cracked wires
SPYDER is offline
post #27 of 33 Old 04-01-2015, 04:35 PM Thread Starter
RIDE RED
SPYDER's Avatar
Battery is out I'll play more tomorrow thanks again hope I can get her sorted
SPYDER is offline
post #28 of 33 Old 04-02-2015, 03:12 PM Thread Starter
RIDE RED
SPYDER's Avatar
http://youtu.be/CyffdHvF4X8
After making this video I came back in and reread the erasure procedure and after clearing codes when jumping the diagnostic plug the mil stays on
I'm going to go start her up and see what I can see
SPYDER is offline
post #29 of 33 Old 04-02-2015, 03:32 PM Thread Starter
RIDE RED
SPYDER's Avatar
She ran for almost exactly 15 minutes then the mil started blinking 19 over and over that's ignition pulse generator I'll trace the wires see if it the connection or if I need to order a new one pretty stoked now I've only got one code instead of all of them lol
SPYDER is offline
post #30 of 33 Old 04-02-2015, 03:40 PM Thread Starter
RIDE RED
SPYDER's Avatar
By test in manual I only get .4 volts out of the ipg so I think it's bad manual says .7 volts minimum WOOHOO!!
SPYDER is offline
post #31 of 33 Old 04-02-2015, 04:41 PM
Yes that would be bad. Be sure to measure it again at a separate time to verify. Ya know, measure twice, cut once. Hopefully this fixes your problem!
Keep us posted.
Pvster is online now
post #32 of 33 Old 04-02-2015, 05:03 PM Thread Starter
RIDE RED
SPYDER's Avatar
I'll check again after the boys baseball practice but 19 is the only code coming up now thanks again
SPYDER is offline
post #33 of 33 Old 04-02-2015, 05:47 PM Thread Starter
RIDE RED
SPYDER's Avatar
After letting her sit and checking again I get 1.2-1.4 volts so I'm thinking the heat of the engine is causing the ipg to fail it's a $40ish part I'm gonna order it and a new gasket just in case I only used grease to hold it in place approximately 300 miles ago but if I don't get a new one it'll stick
SPYDER is offline
