Key and ignition turning issue. - Wrist Twisters
post #1 of 9 Old 08-06-2013, 10:01 PM Thread Starter
Severed's Avatar
Hey guys. I posted here a couple weeks ago about finally getting my 919. When I got it I put the key in it and it turned fine and started right up. Lately when I put the key it it fights to turn and usually takes a minute of me messing with it to get the key to turn to the run position. Then when I turn her off the key struggles to come out of the ignition in both the off and the lock position. I was wondering if this is a common issue or if you guys think it's the key or the ignition that is having problems.
If it's the key will getting a copy made will fix the issue? It doesn't seem bent at all and doesn't seem to have any problems. And if it's the ignition is it difficult to change one out? I suppose there has to be some degree of difficulty to it so people can't simply switch the ignition to steal a bike.
Thanks for the help in advance guys.
"Faster faster, until the thrill of speed overcomes the fear of death"- Hunter S. Thompson
Severed is offline
post #2 of 9 Old 08-06-2013, 10:15 PM
lusting over something...
james_kraska's Avatar
Do you park outside? Since you said your key looks fine, It may be an issue with the barrel getting light surface rust from moisture. You could try spraying some WD-40 in the keyhole and see how that works out for you. If that works, graphite grease can protect it from happening again. This used to happen to my cb650 all the time.
Let me know how it goes!
J
james_kraska is offline
post #3 of 9 Old 08-06-2013, 11:15 PM Thread Starter
Severed's Avatar
J
I do keep it outside for now. I'm in the process of building a garage, but for the moment it has been outside for a while. I'll use some WD40 tomorrow and let you know how it goes. Thanks a lot.
Severed is offline
post #4 of 9 Old 08-07-2013, 12:01 AM
abadacus's Avatar
Have you been unlocking your seat too many times? :P
take a look at your key, are you sure its straight? I Don't know about yours, but mine is made out of cheese. every time I go to unlock the seat, my key will deform slightly. every once in a while I need to put it in the seat lock and twist it in the opposite direction to maintain straightness lol.
When i don't do this, it is definitely more difficult to get in and out
Just as aerodynamic airplanes are simple and streamlined, a motorcycle--which manages to balance an engine and a seat between two wheels--has a mechanical integrity, with intertwining pipes, chains and springs, that is fascinating to behold - Peter Plagens
abadacus is offline
post #5 of 9 Old 08-07-2013, 03:44 AM
Tool & Die
morrow919's Avatar
That definitely sounds like a problem with your key...I'd be getting me a copy made out of some better metal. I've never had an issue with either ignition or seat lock.
Severed,
+1 on the WD-40 to free up your sticky ignition. You might could even use a squirt of white graphite chain lube in there to keep it from corroding once you free it up. Just a thought, never tried it myself.
'07 Hornet - Candy Glory Red
morrow919 is offline
post #6 of 9 Old 08-07-2013, 05:06 AM
My ignition does that occasionally too. I have found that anytime it sits in the rain it will happen more often. So far I have been able to just spray the key down with wd40 and run it in and out of the ignition a few times and it frees it up.
sburton6 is offline
post #7 of 9 Old 08-07-2013, 05:34 AM
If your seat is giving you fits, press down on it while turning the key. Its a trick a Honda master tech taught me earlier this year at The Gap when he saw me battling the seat.
post #8 of 9 Old 08-07-2013, 06:56 AM
VonDonnern's Avatar
FYI....the WD40 is short term release at BEST...and at worst it attracts dust and dirt and forces you to use WD40 to make it release.... the penetrating oil (WD40) will displace the moisture, but it will act to attract dirt and make your lock clunky.
Use GRAPHITE only - it wont attract dirt that way and will keep your lock working right.
VonDonnern is offline
post #9 of 9 Old 08-07-2013, 11:41 AM
sytheii's Avatar
This is most likely an issue with your key, and torque you are applying to the key in different scenarios.
Be careful when you turn your key opening your gas tank, and seat. Pushing down on seat is a good idea when first opening it, when you are opening your gas tank, make sure you are not yanking on the key to pull up the gas cap, pull the gas cap itself.
The ignition is very finicky about your honda key, if it is only slightly bent out of shape, sometimes you will only be able to insert the key on one side to turn, like my key is doing right now. If i put it in one orientation, it will not move at all, if i put it in the other orientation, it will.
I caused this problem one day when i went to get gas, my gas cap is pained black, and occasionally it sticks a bit when pulling up, i made the mistake of pulling on the key, instead of the gascap, and i bent my key way out of shape.
I was able to insert it back into the gas cap, and bend and check, and bend and check, and i finally got it back into a shape that will work consistently with one orientation.
Hopefully you have a spare, if not, get a copy made asap, but test your key out and see which orientation works better, if at all.
Good luck to you.
sytheii is offline
