Installing motech center stand on CA evap equipped bike? Help? - Wrist Twisters
post #1 of 10 Old 10-16-2013, 05:52 PM Thread Starter
Anybody have online instructions for installing a motech center stand on a California evap canister equipped 919? I've got a mount for the evap that's connected to the side stand and exhaust pipe. Not sure if that stays, or goes, but it's blocking the hole for the center stand. Help!
RudyHuxtable is offline
post #2 of 10 Old 10-16-2013, 06:04 PM Thread Starter
Solved it...
post #3 of 10 Old 10-16-2013, 09:23 PM
Once you get everything pulled be sure to lengthen the vent hose from the tank
post #4 of 10 Old 10-16-2013, 10:02 PM Thread Starter
Voodoorider, do you know which hoses to plug?
post #5 of 10 Old 10-17-2013, 06:36 AM
It's been a long time since I did mine, I pulled everything including the solenoid (by the "choke"knob) If you lift the tank there's a vacuum routing diagram, follow the hose up from the solenoid pull it where it joins the vacuum bundle up by the throttle bodies and slap a plug on it
I used one of the hoses that were removed to lengthen the tank vent hose so it hangs down by the right foot peg
post #6 of 10 Old 10-17-2013, 06:39 AM
You shouyld be left with something like this
post #7 of 10 Old 10-17-2013, 01:42 PM Thread Starter
Cool, thanks Dan. Weekend project
post #8 of 10 Old 10-17-2013, 04:25 PM Thread Starter
Dan, did you disconnect the sensor from its source? Looks like it's bundled up pretty tight.
post #9 of 10 Old 10-17-2013, 04:31 PM Thread Starter
Not sure about this! Haha. "Cut the green wire!"
post #10 of 10 Old 10-17-2013, 05:26 PM
Cut the BLUE wire, I wrapped up the connestor for the solenoid in plastic (ziplock bag) and taped it closed then zip tied it to something up where it couldn't be seen. the vent hose you need to lengthen is the one that ran down to the canister
